Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 7.3L Performance Parts
Old 03-19-2006, 09:13 AM
crazyfool502 crazyfool502 is offline
wastegate
i see you guys on here saying you have a wastegate mod i was just wondering what it is and what does it do for your engine? more power? i am new to the turbo diesel scene and how to create more power without destroying my engine can anyone help
Old 03-29-2006, 05:34 AM
dog3434 dog3434 is offline
There are a couple of mods you can do. I personally have the Banks bighead wastegate actuator. The stock actuator has a weak spring that allows the gate to open prematurely. This robs your turbo of boost so you loose power. The Banks Bighead has a much stronger spring, thus allowing your turbo to spool up much more quickly and effectively. Combine this with a WW and you'll notice some minor gains. I also think fuel efficiency is helped but I'm not sure how much.
Old 01-20-2008, 07:48 AM
somebodyelse5 somebodyelse5 is offline
is the banks big head worth the $100+ ?
Old 01-20-2008, 07:58 AM
vitalidle vitalidle is offline
Desert Shield/Storm Vet
Depends I suppose, but you could remove the red air line to the stock wastegate. That will hold the wastegate closed longer for building boost quicker. Make sure you plug the red line. I just put it over the clamp bolt on my intercooler.
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
