Just got an 01 f 350 crew cab srw as far as I can tell it is stock going to pull a horse trailer from time to time about 6000 lbs loaded then just daily driving thanks for any help
Call and get a Hydra from PHP. If the factory turbo is good with no shaft play, get the Wicked Wheel 2. then you can start with bigger turbo/injectors if you need more. Probably gonna need to address the transmission if it hasn't already been addressed
Start with gauges (boost, egt, and trans temp if auto), then do an intake and 4 or 5" exhaust. The riffraff 6637 filter kit is a real good deal for an intake. Then get a chip, I reccomend the Hydra chip.
Been very happy with my Hydra tuner. DEFINITELY get gauges, 6.0 trans cooler and exhaust if you want to tow without breaking stuff. Love knowing how hot my tranny is getting so I can keep after it or back off when need be. (Which is never with the 6.0 cooler.)
Also i would check out all your i/c boots. Riff raff sells a great kit if yours are covered in oil. x2 on the riff raff 6637 intake.
Related Threads
Ford Powerstroke Diesel Forum
5.4M posts
265.8K members
Since 2005
