Buying new turbo and injectors today.. need advice! - Ford Powerstroke Diesel Forum
 5Likes
post #1 of 14 Old 04-19-2017, 02:44 AM Thread Starter
I have a 2002 f350. Truck pulls a 28k gooseneck about 60 miles twice a week. I have the transmission out right now... so now is the time to change up pipes. Current set up is 38r with 160cc 30% injectors. Has tons of shaft play and wheel is kissing the intake side housing. My injectors are worn out. I will be buying a turbo and injectors today. Talked to swamps and they suggested t4 mount with s369 turbo. 200cc 30% injectors. Will I have egt issues ? Seems like a big injector for pmrs and my towing weight. Anyone running this setup ? Thoughts?
Texasag10 is offline
post #2 of 14 Old 04-19-2017, 04:30 AM
blue99stroker's Avatar
Quoted: 270 Post(s)
I'd pass on swamps. And I would pass on 200/30 injectors.
They can't fully empty with a 30% nozzle.
I would get a kc38r and another set of 160/30's.
blue99stroker is offline
post #3 of 14 Old 04-19-2017, 04:32 AM
Quoted: 42 Post(s)
Get a hold of the guys at KC Turbos kcturbosinc@gmail.com
I know they can tell you what the best set up for you would be.
Qholic and darkpassenger like this.
06 F350 KR Promaxx Heads & ARP Studs,Deleted
8"Procomp 2.75 XX75 Dual Coil-overs
MKW 22x11 M26 -24 Offset,Toyo MT 37x13.5x22
MBRP Straight 4 Inch Exhaust,MBRP Up-Pipe
Fabtech Dual Sterring Stabilizer
Pro Comp Traction Bars
SCT Live Wire & Probe
Sinister Coolant Filter System
BPD Water Pump,Mishimoto Rad
Rudy's Diesel CAI 150.00 Cheaper than Sinister's
7.3L Fan, 6.4L Banjo Bolts Blue Springs
HornBlasters Conductor's Special Model 240 Train Horns
Synthetic with Hotshot Additive
Alpine W960 Touchscreen W/T Backup Camera
JL Audio Stealthbox Center Console W/T Rockford Fosgate AMP
2012 Can-am Outlander 800R Camo
2005 Excursion 6.0L
"I'm out old man. I'm just a pecker-wood who lives in the woods with too many guns. Ya happy?"
BridgerMT is offline
post #4 of 14 Old 04-19-2017, 05:09 AM
sbluke55's Avatar
Quoted: 570 Post(s)
Garage
Like I said over on psn. I don't think the 200/30's are too bad. Being a hybrid it will use less oil and will be easier on the hpop. The 30's will have good atomization and help keep the egts down. They should run about the same as your 160/30's in a tow tune. Plus @Chatham036 from php said it was his favorite injector to tune.
My concern was the turbo. I think the s369 is to big. A 364.5 would be better. Or a kc38r turbo so you don't have to swap over to a t4 setup but your at about the same price when you factor in bellowed up pipes. Also @peixinho is coming out with a dual ball bearing 364.5 here soon hopefully.
peixinho and darkpassenger like this.
01 f-250, Standard
Rev tech 4" lift,37" military wrangler Mt tires
KC diy 66, Full force 160/100 and custom tunes from PHP
Banks inner cooler and full 4" exhaust, Diy S&B intake
Diy quad feed, Hydra, Isspro boost, pyro, and fuel pressure
3/0 battery cables with military style terminals
sbluke55 is offline
post #5 of 14 Old 04-19-2017, 06:04 AM Thread Starter
Ok,
I already have fairly new bellowed up pipes. I put those in with my 38r. I just got a bad taste after the Garrett 38r. It lasted a whole 10 months! I don't know if Kc turbo will last longer or not. But I know the borg turbos have a more robust center section. Just hoping to get some more longevity!
post #6 of 14 Old 04-19-2017, 07:20 AM
Quoted: 270 Post(s)
did the 38r have a billet wheel installed?
They usually last 200k+ plus miles with good maintenance and not pushed over 40 psi.
post #7 of 14 Old 04-19-2017, 07:40 AM Thread Starter
Yes it had a billet wheel installed
post #8 of 14 Old 04-19-2017, 10:24 AM
Quoted: 270 Post(s)
Ya most 38r's that have a billet wheel installed die just like yours did.
In stock form they last a very very long time
post #9 of 14 Old 04-19-2017, 08:38 PM
Justin@DP-Tuner's Avatar
Quoted: 60 Post(s)
Billet wheels are not a good idea on the 38R. They do well on a stock turbo, but the stock cast wheel out-performs them on the 38R. Have also heard of many issues with them prematurely taking the turbo out.
Did you ever run the 38R with the stock cast wheel?
Also, my recommendation for you would be 180/80's and 364.5 or 366 turbo, as I said in your thread on PSN.
DP-Tuner
For Your Tuning Needs
Like us on
Justin Bochmann
Sales and Technical Support
828-221-0076 ext.804
Justin@DP-Tuner is offline
post #10 of 14 Old 04-20-2017, 05:44 PM
peixinho's Avatar
Quoted: 214 Post(s)
I agree with what everyone else said. A 369 seems a tad big for your goals. Maybe a 364.5 or 366 would be better.
Also 30% nozzles are pretty small for a 205cc injector. But that wont really hurt anything, you just won't empty all the fuel on a normal/safe PW tune.
We are going to debut our new drop in s369 for the 7.3 this weekend at the UCC. Details will be up on our facebook page for anyone interested. We are very excited about it... but it will not be available to the public for a little while longer, we still have some testing to do. If all goes well then we plan to offer a 366 and 363 version very soon.
darkpassenger likes this.
KC Turbos
Warren Diesel Dealer
My Current Build Thread
Current Setup 190/30 and KC 64mm Stage 2 turbo
peixinho is offline
