Injectors for a 2000 - Ford Powerstroke Diesel Forum
post #1 of 17 Old 11-20-2009, 01:27 PM Thread Starter
7.3ford350's Avatar
Send a message via AIM to 7.3ford350
i have a 2000 f-350 with the 7.3, it has 115,000 on it and i have to replace the injectors, was wondering if some of yall could help me with this, i dont want to spend $275.00 per injector for stock one and not get somethign out of it, being as i have to spend this money i would like to gain something out of it. the tranny has been upgraded minner, and i have all the other mods in my sig, i am wondering would it hurt anything for me to put a set of stage 1's in but not have to add a fuel system or oil system, or replace the tranny in 6 months. any suggestions are great.
thanks
george
2000 F-350 Beans diesel performance stage 1 injectors, Beans tunes 6 pos, EBPV delete, ITP boost regualtor, itp pre pump/fuel tank kit,dino fuel cross connect kit and hpx line, trans,pyro,boost and fuel presure autometer ultralite gauges, full exhaust, wicked wheel, Intake, BD Waste Gate, foil delete
2008 F-550 6.4 12ft dump
2006 F-450 6.0 12' dump
2003 F-250 5.4 gas
2006 Ford Ranger
CAT 305CCR EXCAVATOR, 289C SKIDSTEER, 257B SKIDSTEER
7.3ford350 is offline
post #2 of 17 Old 11-20-2009, 02:05 PM
<< Representin with INK
Grease Monkey's Avatar
What do you have done to the trans? With the stage ones in a single shot since your having it retuned anyways you can have them turn down the injectors to act near stock levels but still have a little difference. Then when you do further upgrade your tranny and other things to handle excessive power levels you can have it reburned and maybe nozzles added for some good power gains with enough airflow to supprot them as well. Why such a soon replacement? What went wrong with the stock ones?
00 3/4T Ext/Cab SB 4wd
Any and All diesels in Southwest welcome to join!
GREASE MONKEY KUSTOMS Rod & Speed Shop Open 2010
Grease Monkey is offline
post #3 of 17 Old 11-20-2009, 02:23 PM
Tony V's Avatar
Hey I might have all 8 for sale very soon. I bet we could work something out.
2000 F-250 216k- smoke much?
Facebook: Anthony VanCamp
Add me if you'd like
Tony V is offline
post #4 of 17 Old 11-20-2009, 03:05 PM Thread Starter
7.3ford350's Avatar
I just have a upgraded vavle body and converter, I thought I had to have split shot injectors, I didn't think I had single shots.
2003 F-250 5.4 gas
2006 Ford Ranger
post #5 of 17 Old 11-20-2009, 03:13 PM
Tony V's Avatar
you have split shots... I will be selling mine out of my 2000 they are Split shots
Tony V is offline
post #6 of 17 Old 11-20-2009, 03:15 PM
BadDogPSD's Avatar
Quoted: 3 Post(s)
There's a guy over on PSN selling a set of new AD's for $1500
2013 F350 CC LB 4x4 Lariat
BadDogPSD is offline
post #7 of 17 Old 11-20-2009, 03:16 PM
Tony V's Avatar
Are those stock?!
Tony V is offline
post #8 of 17 Old 11-20-2009, 03:29 PM Thread Starter
7.3ford350's Avatar
I would rather try and get a set of stage 1 providing I am not going to upgrade everything
2003 F-250 5.4 gas
2006 Ford Ranger
post #9 of 17 Old 11-20-2009, 03:34 PM
Tony V's Avatar
Ok well I just thought I'd throw that out for ya. Im probably gonna sell all 8 for only like around 400obo. prob not even that.
Tony V is offline
post #10 of 17 Old 11-20-2009, 03:52 PM
You do have split shots, you DONT have to KEEP them tho. If you have your chip reflashed, some places will do it for free with injector upgrade, or for a small fee. If you swap to single shots they are a tad bit louder than a split shot at idling but the same while driving. You will however see a marginal ecomony gain with single shots vs split shots if your shooting for best economy the single shots win hands down. Even with a bigger injector roughly, you can gain some mileage without a heavy foot and without really big nozzles. I would say that some 160cc single shots with stock nozzles would be what your looking for. The stock 17* pump should handle them fine, your tranny should be ok if you dont race your truck or beat on it really and with the custom tunes you can have them turn them down to just above stock or to about 50hp above stock if i belive depending on your other mods and trucks running state and effiency and etc. Check out some casserly injectors or beans, most reman 160s with stock nozzles are just above a grand and are really the best bet if you dont want to rebuild yourself or pay a shop labor charges to rebuild them. Hope this helps, also If you want to learn more about the difference between splits and singles and nozzles vs injector size and so forth swamps diesel is a really good place to learn about our powerstroke motors
