Figured I'd be the first to wright a review on diesel sites new turbo its a little bigger than I think my stock injectors can handle but it spools really nice and sounds amazing but for some reason my egts went up almost 200° I check all my boots and exhaust v band clamp and put in new donut gaskets but their still really high but all in all its a very stought turbo
Ya I already tried it unfortunately. I have all riffraff boots on it and I siliconed them on the CAC tubes and I didn't have any leaks I'm thinking I need to hook up to a good scan tool and check how my IPR is reacting cause it smokes quite a bit even when I had my stock turbo on it
I'll recheck my up pipes then and my fuel psi is 65 and my hpop peaks at 2900psi I had it hooked up to a scanner a couple months ago for another reason that ended up being the cps
Sorry I just seen this post my gmail put it in spam. I love the turbo but I need to look into some tunes because its not quick to spool I just put it on my freshly rebuilt engine 2weeks ago it sounds amazing but my egts are thought the roof but a good chip I think should fix it I'll let you know this Weekend I'm gonna put my superchip back in I took it out to break in the new motor
I just did today and it made a world of difference, we'll see how she pulls now I only got to drive to work but on the 10% grade their my egts were down almost 200°
Well I towed a 10,000 pound load from Arizona to Florida and had nothing but egt issues I'm gonna try a .84 housing and see if that helps or put the stock turbo back oni don't wanna buy new bigger injectors just cause the turbo won't spool I talked to diesel site and they said it was more for stage one injectors I just like how quiet stock splits are
I did they said it will work and the problem is any rpm below 2100 my stock really liked 1800 but now I have to run tow haul mode till 65 then let it shift or else the egts shoot right up to 1200 quick
Thanks for the reply. I am looking into getting one for my E99. Would you have done anything different with which size one you would have got the 66mm or the 60mm one? Good news on the sound. I have been in a 38r truck before and they get annoying after about an hour of driving.
Related Threads
Ford Powerstroke Diesel Forum
5.4M posts
265.8K members
Since 2005
