Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 7.3L Performance Parts
Old 11-06-2009, 05:38 PM
TuRBoWHiNe TuRBoWHiNe is offline
Active Duty Marine!
Send a message via Yahoo to TuRBoWHiNe
TW Chip issues
Ok Gents,
I just put a new TW Chip in my truck. 03 7.3 with standard mods. When I go to start it up, the Wait To Start Light takes longer than normal and it then cranks with no start up. I tried it in all 6 Positions on the switch with the same results. When the truck was returned to stock, it started right up.
Any ideas?
Old 11-06-2009, 05:53 PM
Strokeorcroak Strokeorcroak is offline
Send a message via AIM to Strokeorcroak Send a message via Yahoo to Strokeorcroak
Clean off all the contacts between the chip and the computer... gunk gets on there and causes all sorts of problems!!!.....
Old 11-06-2009, 05:57 PM
Active Duty Marine!
Are you saying to clean the contacts on the chip as well? The computer is clean, and i will clean it again just to check...
Old 11-06-2009, 06:00 PM
Dont clean it to much though... over cleaning it can screw it up!!!
If you think its pretty clean then it must be. Otherwise give tony a call because something with the chip may be wrong. Your wait to start light should stay on less than usual not more
Old 11-06-2009, 06:04 PM
Active Duty Marine!
I wonder if it is too clean. I had my dad clean it for me. He was an electronics tech in the Navy for 24 years. Now I'm reading all the don't clean it too much posts and am concerned. If that is the case, what's they cure?
Old 11-06-2009, 06:05 PM
A new PCM is the only way to go... how much brass is showing on the contacts of your PCM?
Not much at all should be showing
Old 11-06-2009, 06:10 PM
Active Duty Marine!
He cleaned it all off....
Active Duty Marine!
By cleaned it all off, I mean you can physically touch brass on the entire contact, every one of them...
Old 11-06-2009, 06:13 PM
can you get a picture of one? I am almost certain that may be your problem! to much brass is not a good thing... All he needed to do was clean the wax type stuff off the contact until a TINY bit of brass was showing. A new PCM is pretty spendy too!
Old 11-06-2009, 06:14 PM
Active Duty Marine!
Well, luckily he knows what the name of that wax stuff is as well. We shall get some of that, put it back on, and try again... I'll show a pic as soon as I find my cable...
