Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 7.3L Performance Parts
  #21 (permalink)
Old 11-06-2009, 12:35 PM
Big_Stroker Big_Stroker is offline
Send a message via Yahoo to Big_Stroker
Originally Posted by RaZe View Post
To all of the people chosing Gearhead.... you seem to have new stick and turbos pushing some bigger numbers with bigger gear.
If i were to run Matt's tunes on my truck with just
- 4" straight pipe
- AFE stage 2
- Autometer gauges Boost, EGT, trans temp
- SP boost fooler
.......... would i get higher numbers on the dyno runs rather than PHP or TW ????
For one thing with Matt's OR Bills tunes from PHP you dont need a boost fooler... You will see better numbers with out it because the use the MAP for fueling and want to see what max boost is.
But to answer your question I don't think you will see much higher numbers on a stock truck.
Reason I see high numbers with little mods is because of my ported heads and Matt has spent HOURS perfecting the tunes for my injectors that I have from Unlimited.
  #22 (permalink)
Old 11-06-2009, 12:38 PM
BIGBILL105 45 BIGBILL105 45 is offline
I'd go with PHP since Bill has been around longer than basically any other tuner and Tony has been having some family medical problems and there is quite a long wait. Both are great choices though.
  #23 (permalink)
Old 11-06-2009, 12:40 PM
Don't get my wrong I like Bill and one of my buddies is running his tuning on his stock truck. But just because someone has been around longer means they are better at something then someone else.
  #24 (permalink)
Old 11-06-2009, 12:45 PM
I never said that he was better or not better. I just used that as a reason. I should of used the reason that he has a good first name.
  #25 (permalink)
Old 11-06-2009, 12:51 PM
GM Duraturd GM Duraturd is offline
I have Tonys tuning and love it. Tony is a great guy to do business with also. I plan to stick with Tony but if I ever decided to change for some reason I would go straight to PHP without hesitation.
While talking to Tony the #1 thing I got out of it is that every truck reacts different to different programs. People here saying that they got better mileage with daily than econo and more smoke in extreme than smoke, etc are absolutely right on their truck, however that does not mean that every truck and setup will react the same way.
Good Example: Me and Jake meet up with Tony in Cleveland a month or so ago. He put a drive thru tune on Jakes truck and it did nothing at all. Tony said he put the EXACT same file on a truck the day before with the same computer code, same year, same mods, same everything and it worked perfect on that truck. Also Tony tried to make the other guys truck lope and it would not at all no matter what he tried...again put the EXACT same program on Jakes truck and it loped insanely.
  #26 (permalink)
Old 11-06-2009, 12:59 PM
Strokeorcroak Strokeorcroak is offline
Send a message via AIM to Strokeorcroak Send a message via Yahoo to Strokeorcroak
What did it cost you to get live tuned?? I need that badly! Especially once i get my H2E and hybrids next year
  #27 (permalink)
Old 11-06-2009, 01:01 PM
We didnt get live tuned, just made a few changes on the computer for free one night, only took like a half hour. He was already up here in Ohio so we just stopped by his hotel to chat and get a quick reburn.
Live Tuning from Tony is $50 an hour, with a minimum of 4 hours plus the cost of the chip (which you already have). So $200 if it only takes the minimum time.
  #28 (permalink)
Old 11-06-2009, 01:06 PM
It wouldnt be worth that with my setup right now... basically stock.
But once i go to bigger and better things I think i will get it live tuned from someone!
  #29 (permalink)
Old 11-06-2009, 02:01 PM
RaZe RaZe is offline
i am having the same trouble chosing between TW and PHP
i hear great about both......but it all comes down to numbers
TW= First Dyno and I was impressed TW rocks.
PHP= ?????
ANY ONE have dyno results for PHP on a 7.3 with basic mods(intake, straight pipe, gauges)???
  #30 (permalink)
Old 11-06-2009, 02:21 PM
tubular031 tubular031 is offline
I would go with Tony or Matt at gearhead.
