Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 7.3L Performance Parts
Old 10-31-2009, 08:30 AM
DJM DJM is offline
Fass Pump
Anybody that has installed this pump wich fuse did you splice into? Gona install it once the rain stops for a day.
Old 11-01-2009, 08:00 PM
vegginpsd vegginpsd is offline
Splicing into an existing line except for the power that is already there for the stock fuel pump is really not a good idea. The best way is to put a relay in there and use a trigger wire from a keyed source. If I recall, the FASS pump is 23A motor. Takes a lot of juice to run them, but there are an awesome pump!
Old 11-02-2009, 09:19 AM
tubular031 tubular031 is offline
I would install a fused line from the battery to a relay then run the line to the pump. use the + line on the plug on the stock pump to act as the triger for the relay. Key on, PCM says turn on fuel pump triggers the relay and FASS comes on. I think on my FASS I am useing a 25 o 30 amp fuse. No blown fuse yet.
Old 11-02-2009, 10:46 AM
If I remember correctly, the Maxi Fuse in the master power distribution box for the fuel pump is 30A. So a 30 A innline would be about right.
Old 11-02-2009, 08:11 PM
DJM DJM is offline
Never thought of usin a relay I was just lookin through the instructions and was goin off what they said thanks for the info
