- HOME
- FORUMS
- GARAGE
- ARTICLES
- CHAT
- CLASSIFIEDS
- VIDEOS
- TECH
- STORE
| LinkBack | Thread Tools | Display Modes |
| Sponsored Links |
Yes you cut the Blue/Green wire and put a resistor inline. From what I've read (as I'm new to this) this works opposite and better then just connecting the resistor btw the two terminals. Best to use anything from 10K to 22K if using this method. The ICP sensor resistance increases with intake manifold pressure. The PCM reads the voltage drop on the Blue/Green ICP return line (Higher resistance = higher voltage drop) It compares this voltage drop to the drop across the reference resistance (Grey/Red 6KOHM). PCM uses the difference between these two voltage drops to determine how much fuel to add to the mixture. So putting a resistor inline with the ICP return (Blue/Green) increases this difference. If you do it the easy way and just hook the resistor between the ICP return and the reference lines then you are putting the resistor in parallel with the reference resistance thus decreasing total resistance. This is all based on what I've read over the past couple of nights. I wish I could see the circuit to better understand exactly what is going on. |
This may have already been covered and I just haven't found it yet. |
This is from my other thread listed above. Quote:
RRonning it looks like you've got a 10K in parallel with the 2.2K which is on a switch which is in parallel with the reference resistance (6K). Putting the 10K in alone drops your reference voltage down from 6K to 3.75K. Flipping on the 2.2K switch brings the referenc voltage down to 1.39K. Each step down creates a greater difference in voltage drop between the ICP voltage drop and the reference voltage drop. Hence the added power of the 2.2K 1/X = 1/6K + 1/10K + 1/2.2K |
| Sponsored Links |
