This is my next upgrade and Im not sure If I have this all correct. Based on what I have been reading on here and there sites I have these 2 options to choose from.
CNC FAB
CNC FABRICATION 7.3L E99-03 COMPLETE REPLACEMENT HPOP AND HPX LINE KIT CNC-SD-HPOPLINEKIT-HPX $165
CNC FABRICATION 7.3L E99-03 COMPLETE REPLACEMENT HPOP AND HPX LINE KIT CNC-SD-HPOPLINEKIT-HPX - 99-03-ENGINE - POWERSTROKE 99-03 - Products
CNC FABRICATION 4 LINE FEED 7.3L SD FUEL BOWL RETAIN KIT $250
or
RiffRaff
Riffraff Diesel 7.3L Diesel Fuel Rail Crossover™ (FRx) $189
7.3L Diesel Fuel Rail Crossover? (FRx) 99-03 Powerstroke
High Flow Fuel CVD Fitting Set $29
High Flow Fuel CVD Fitting Set for Ford 7.3L 99-03
Parker 60VLV-4 Viton Sleeve (1/4 inch) $6
9/32" Square Female Pipe Plug Socket $8
9/32" Square Female Pipe Plug Socket for Ford 7.3L 99-03
(1? 2?) Riffraff Diesel High Flow Banjo Bolt - 7.3L $50
Riffraff Diesel High Flow Banjo Bolt for Ford 7.3L 94-03
*Stainless Steel HPX 99-03
Stainless Steel HPX for Ford 7.3L 99-03
Is my thinking correct? Do I need to do anything else when I do these mods also?
CNC FAB
or
RiffRaff
