STACK
758 views 6 replies 4 participants last post by  CloverLeafFarm
#1 ·
I just installed the Edge Products Juice w/ Attitude Monitor on my 02 powerstroke. I have had great results with this product. I had the superchip programmer on it before. The Edge says you cant stack with it. I was wondering if i could put the superchip back on the truck?
I also keep reading about the TW chip, can that be stacked with the edge?
#2 ·
No you can't stack em.
If you just got the TW chip you would more than likely be much more impressed than with either of those other two power adders IMO
I think you can still use your attitude monitor though for gauges if you liked
#3 ·
See when i got the edge it said it could be stacked so i was just trying to find some info out
#4 ·
The only thing you can stack with it is an ICP mod such as the Edge EZ box or a 10K mod.
#5 ·
Yea you can stack it with the ez. Forgot about that. I don't think its worth it though IMO. I had an ex plugged in my icp connection and a bullydog in the pcm. Didn't add any power at all just a bit more smoke.
I've always wanted to try the edge evo II
#6 ·
okay thanks for the info so were do i go to get tw chip
