parallel twin turbo - Ford Powerstroke Diesel Forum
Old 10-17-2009, 01:04 PM
parallel twin turbo
is it possible to or has anyone seen it done to put a twin turbo kit on a psd in parallel with one turbo on each bank of four cylinders. given the v design of the engine it should be possible to put a turbo manilfold on each bank which opens up the possibility to quad turbo your truck if built strong enough. anyone ever seen this or tried it?
Old 10-17-2009, 01:24 PM
Yes but noone has made it worth wile to do. Not really any point. You get a lot more boost and a lot more air to it with compunds.
Old 10-17-2009, 01:26 PM
wriott
Guest
Posts: n/a
there is a thread over on PSN about a parallel turbo truck that is built and running...
Old 10-17-2009, 01:28 PM
yes someone on here has the setup search it
Old 10-17-2009, 01:48 PM
Built and running and built and working well is two different things though.
Old 10-17-2009, 02:10 PM
What he said ^^^^. They are just not as efficient as compounds.
Berm Buster
Im sure it would work ok but I think that running compound turbos to all 8 cyliders would be just as good if not better. You can push an easy 60-70 lbs of boost with twins and that is more than you need in a 7.3.
Old 10-17-2009, 03:11 PM
Audi does it on the V8 TDI engine, so it is do-able.
Old 10-17-2009, 03:14 PM
Heres the thread...New Parallel Turbo Project - Powerstroke Nation I think its pretty neat .
Old 10-18-2009, 05:55 PM
paralell turbo
he is using it for sled pulling and it is working very well. I for one would think
that could lead us in a new direction. Ford is even looking at real twins.
