fuel bowl delete
Hey guys. I have been putting together parts to build my new fuel system and i have a question. when you do away with the stock fuel bowl what do you do with the sensor plug in?
My system I am building consist of doing the in-tank mod followed with a CAT 10 micron fuel water seperate and pump then to the factory pump then through a CAT 2 micron filter up to my home made RR and bowl delete that i am still working on. I will put up pics soon. |
you want to do a pre pump filter and post pump, before it hits the regulator
the cat fuel/water seperater is a 10 micron filter that is pre pump and the cat base and filter is after the pump and it is a 2 micron filter
sounds good to me! btw the plug just goes to the heater in the bottom of the bowl, I think you just leave it unplugged
thanks. thats what i figured just wasnt sure. im just going to use a -6 jic tee fitting instead of buying the y block to delete my fuel bowl. and i am using cat single wire 3/8 fuel line from the tank all the way through entire system. i think it will work great.
how much did the cat 2 micron setup run you n whered ya get it?
i have a really stupid question but what is the purpose of doing a fuel bowl delete unless you have aftermarket injectors
no ? is stupid. hes prob gettin everytin ready for injectors like me
that makes sence then i thought i was missing somethin
yeah saving for injectors, got the filter set up off an old engine at work, freeby.
I am a field tech for a CAT dealer thats why all the CAT stuff. |
