diy intake - Ford Powerstroke Diesel Forum
Old 10-11-2009, 12:35 PM
diy intake
i searched and looked at pictures of peoples diys and noticed some dont have a box to keep the engine heat away from filters. dosent that kinda defeat the purpose of a cai?
Old 10-11-2009, 12:38 PM
not so much because your intercooler will cool it down anyways. the benefits far outweight the costs with the diy mod
Old 10-11-2009, 12:41 PM
with all the gas burners ive had you needed a tune to make up for the extra air. is that needed with a psd? and dose the zoodad make that much of a difference?
Old 10-11-2009, 12:43 PM
o and what size pipe should i used for the intake, 4 or 5 inch?
Old 10-11-2009, 01:29 PM
the stock ford air intake is majorly restricting, getting air in(diy intake) and out(straight pipe) is the name of the game as far as keeping your temps down and opening up some power, if you do it just keep your stock set up if you dont like it what says you cant put it back in, but you wont youll love it
Old 10-11-2009, 01:32 PM
No you dont need to tune for differences.. though when you get a custom burnt chip they will probably adjust a few things to optimize it.
"cold" air doesn't matter on a turbo car.. the second that air touches the turbo it's instantly super heated anyways. It's just a matter of getting the air TO the turbo more bountifully and easily.
The zoodad is ok but not really needed w/ the 6637. The intake piping is 4".
Old 10-11-2009, 01:56 PM
thanks for the info. this is my first charged engine that i planned on doing any type of tuneing to. as far as a new down pipe can i do a dyi or is that something you have to buy from a exhaust company
Old 10-11-2009, 02:32 PM
a downpipe for your exhaust? You need to buy one.. there is no way to diy that. Those really aren't much of an issue on stock trucks though. That would be towards the end of the list, or right before you buy a bigger turbo and injectors.
Old 10-12-2009, 10:01 AM
Feedback Score: 5 reviews
Read..best intake - Page 4 - Powerstroke Nation
If link doesn't work...
Sorry for the late response. caryt asked me to comment on a few threads, this being one of them, a while ago and I’m just getting around to it. However, on a new computer (yea!… sort of… depends if you like Vista).
Anyway, I don’t monitor all the different forums anymore, but am always willing to comment if anyone would like to link me to the conversation you are having. Since I am a bit late, I’ll respond to the posts as they appear and hopefully it won’t be too confusing.
quote:
“have a used AIS…couldn’t find a filter for it…got a FIPKI K&N system cheap…should I put a tymar on or put the AIS back on??? I was thinking of mounting a tymar to the K&N tube…what do you guys think”
The K&N element should probably be avoided in turbo-charged applications. The initial filtration efficiency is not high enough to protect the compressor impeller.
The phrase “mounting a tymar” sounds kind of like Tymar is a filter. The filter we use is a Donaldson B085011 and Tymar is a company name. Tymar Performance makes all sorts of items, one of them being the open element intake kits.
That said, the element we use would not fit on the end of a K&N FIPK system. I guess you could technically modify things to get it in, but you wouldn’t have minimal radial clearance around the filter, which should be considered very important to providing low restriction air to the turbo. Without supplying minimal radial clearance, you won’t get the positive benefits the open element system should create.
The AIS will provide excellent filtration efficiency, but will not improve overall restriction or allow much additional air flow in the configuration that Ford uses. The Tymar Intake will provide excellent filtration efficiency as well as decrease restriction to the turbo and add significant air flow.
quote:
“Tymar is going to give you better flow but AIS is going to give you unmatched filtration…the AIS plus it will last a LONG time, like 60K miles…”
Although the AIS will give better filtration efficiency, you are only talking about 1/10 of a percent over the filter Tymar Performance Intakes use at initial filtration efficiencies. Not enough of a difference to really differentiate between the two.
For the longevity, you have to start talking about restriction ranges in both stock and aftermarket applications and how dirt will affect them. AIS has a larger capacity, but not across the restriction ranges once installed on the truck. Because of the configuration you are not lowering restriction significant over stock levels, but you are receiving better filtration compared to the stock intake.
The Tymar Intake will allow lower restriction levels and lasts approximately 15K miles in a restriction range LOWER than stock. If you want to go with longevity of filter, you can continue using the same filter and will simply not experience the positive benefits of lower than stock restriction levels.
We supplied the intake systems for Granite Construction and used them as a severe duty use test. They were rebuilding Power Stroke engines at approximately 60K miles because of the fine silt in the mining beds. After changing to our system they were using the same filters with 28K mile change out intervals and only experiencing 32”h2o of restriction (yellow on your stock restriction gauges) and they eliminated the necessity of engine rebuilds and were selling the used trucks with over 180K miles on them.
quote:
“I'm using a tymar because it's cheap to setup and offers good filtration.”
Although I agree with you, your listed intake is a DIY 6637, which is neither a Tymar nor a recommended system by us. The WIX/NAPA 6637 is not a hydrophobic (water resistant) element and using it as an open element should be avoided. There are other concerns such as providing minimal radial clearance, isolating engine vibration, positioning away from rain drip channel, etc. But, I just wanted to draw a clear difference between copies, DIY efforts, and our product.
quote:
“…be sure your Tymar-type filter includes the PowerCore filter media and not some lesser media material.”
Although the PowerCore ® media is far superior to most other media, there is not a PowerCore media filter available for use as an open element. They are inserts for intake boxes and are not configure for use as filter alone applications.
The filter media is not the main attraction, but the filter configuration. It is NOT true that you cannot get the same filtration efficiencies or flow rates from other Donaldson products. It will just simply have to be larger. The PowerCore configuration allows for compact applications that have flow rates and filtration efficiencies of filters much larger. So it is the compactness of the element and not that the media processes some magical qualities.
quote:
“IMO, the FIPK tube with the heat shield and the Donaldson (aka #6637) filter combination is hard to beat for the money.”
I would probably respectfully disagree. The problem is the thickness of the stacked gauze media will not allow for a high pleat count and severely restricts the available surface area. A typical RD-1460 that is used in a FIPK system only has about 44 pleats. The Donaldson we use is not only a larger filter overall, but the thinner media allows for 202 pleats, leaving us over 5 times the surface area to pull from. This is why we can outflow and out filter a re-usable element as long as minimum radial clearance is maintained.
The problem with heat shields and routing air through intake boxes is that whenever you direct air flow, you increase restriction. Low restriction is the goal, so using a filter that has the ability to flow large masses of air and then enclosing it in a box yields very poor results. Heat shields do literally nothing. Air flow under the hood is dynamic and not static. It is moving all the time. Hot air will move right around a heat shield at the same temperature and be ingested and the only thing you have caused is turbulence.
Aside from impeding minimal radial clearance and isolation of engine vibration, a serious cause for concern is placing the filter, especially a 6637 element, under a rain drip channel for the hood. Beyond the ambient moisture that will cause restriction as it is absorbed into the non-hydrophobic media, you will be directing water towards the filter anytime the rain drip channel flows more rain than it can hold or spills over the retainer during left turns.
I’ll try to check back in and address further comments in the days to come and can hopefully shed some light on why we do what we do using the configuration we did.
Peace to all, enjoy those rigs!
__________________
Old 10-12-2009, 11:45 AM
Now my 01 250 air box has a sensor in it what do I do with it.
