Urgent TS chip install HELP! - Ford Powerstroke Diesel Forum
Old 10-05-2009, 04:28 PM
I have the computer and it says use laquer to clean the ports can i use rubbing alcohol on the scotch pad?
And its the 6 position so how do i plug it in the termanels???
Please shed some light
Old 10-05-2009, 04:42 PM
BIG TRUCK, SMALL DRIVER
yes you can use alcohol and scotch pads. just make sure you clean the contacts well. this will give you an idea of installation, good luck!http://www.totaldieselperformance.co...stall94-97.pdf
