Tuner at 300,000 miles? - Ford Powerstroke Diesel Forum
post #1 of 15 Old 10-04-2009, 06:20 AM Thread Starter
recently got a early 99 f350 with an auto trans with 300,000 miles on it,it has a 6 inch lift & 35's,my question is will it hurt to put a tuner on it with this milage?has a k&n filter in the stock box & am going to replace factory muffler with something that flows better,want a chip that actually does help the trans,any suggestions would be appreciated,thx...r
longrange223 is offline
post #2 of 15 Old 10-04-2009, 06:37 AM
jared118's Avatar
do it, if you dont have studs just put it on a fuel economy tune.
jared118 is offline
post #3 of 15 Old 10-04-2009, 06:44 AM
im at 302,000 right now and my truck is chipped. im changing to the dp tuner but ive been hereing alot of good stuff about tw also so its a hard choice.
4 inch Banks Exaust
Stage II AFE Intake
Banks Chip
Halo HID Projector Healights
LED Taillights
LED 3rd Brake Light
Pro-Comp 3 Pod Guage Pillar
Billet Grill
2" Leveling Kit
Rear Air Bags
Future Projects:
CCV Mod, Zoodad mod, Injectors, And DP Tuner
Bambam03stroker is offline
post #4 of 15 Old 10-04-2009, 06:54 AM
Justin M's Avatar
Quoted: 2 Post(s)
Just have mechanic check everything out, but dont mention what you are gonaa do. See what he says about the engine, and go from there!
MINE - 1997 F-350 ZF5 XL
WIFES - 2006 F250 Lariat FX4
Justin M is offline
post #5 of 15 Old 10-04-2009, 07:29 AM
WNY Biodiesel Co-op
greasyF250's Avatar
Quoted: 6 Post(s)
A tuner puts extra stress on the motor and drive train if you like to play with the settings ( holeshots 4x4 boosted launch etc). If you use it with discretion, you should not have many issues.
2000 F250 King Ranch Crew Cab 7.3L LB 4X4 100% home brewed Biodiesel
ZF6 6SPD trans
Zoo Dad Mod
DP F5 Tuner
Wicked Wheel
AFE Intake
4" straight exhaust with 5" tip
Isspro 3 Gauge Pod
285/75/16 Cooper ATP on factory 16's
Banks Big Head
298K
greasyF250 is offline
post #6 of 15 Old 10-04-2009, 07:38 AM
Powerstroke Junkie
NCHornet's Avatar
That K&N in the stock air box is going to destroy your engine long before a tuner will. You need to do the supporting mods before adding more Ponies, if you do these and not drive it like you stole it than a good tune from DP, TW, etc... will only help your powertrain. I know for a fact that my truck works less to do the same job as it did prior to mods, this should equate to longer service life.
NCH
NCH
Proud Father of USAF Airman
2000 F350 DRW,CC,LB, 4X4, Western Hauler Pkg.
Ford AIS/ BTM, FTVB
My CCV MOD, Coolant filter
06 Grill, 05 lights,6.0 trans cooler
Cyro/Hawks, JVC Touchscreen HU, JL C5's, Infinity 800watt amp,
DP tunes, 60 tow/80 e/120 race, on a SCT2 tuner
P3 controller, Brite Box Turbo Lifesaver
KMC Wheels x 4
Friends Don't Let Friends Drive Trucks With Generic Tunes
NCHornet is offline
post #7 of 15 Old 10-04-2009, 09:07 AM
blowinsmoke7.3's Avatar
I personally would stray away from DP...especially at that many miles
JMHO
99.5 F-250 Lariat 4x4 CC
-Isspro's in A-pillar
-5" TB into 6" miter
-Recon smoked cab lights
-Bullydog "mileage" chip *Matts tunes in 2 weeks*
-Warn hubs
-DIY intake, Foil delete
-Hankook MT 285's
blowinsmoke7.3 is offline
post #8 of 15 Old 10-04-2009, 10:17 AM Thread Starter
what chip would you guys recommend? looking mostly for for a little more power but mainly to help the transmission...r
post #9 of 15 Old 10-04-2009, 10:19 AM
Cumminskiller2007's Avatar
im at 430K and running a SCT with custom tunes
2001 F350 S/C 4x4 DRW 6spd
475K
DpTuner-high idle, 80E, 100Perf, 120Race, 4inch TB exhaust with 5in. Single black Stack, Custom 4in. intake with AEM dry filter, ISSPRO boost,pyro and water temp, zoodad mod, Beans 1.0 A/R non wastegate turbine housing
Cumminskiller2007 is offline
post #10 of 15 Old 10-04-2009, 01:16 PM
I recomend Matts tunes to every one simply because thats what i have and love them. No problems what so ever. All custom tuners can tune your tranny (shift points, line pressures, etc) to your likings
Hope this helps
-Warn hubs
-Hankook MT 285's
