Shes still a terd!!!
I've got a 99 7.3 that I put an edge juice with attitude on, straight piped it and she is still slow and hardly blows any smoke. What is wrong with her?
the edge
lolwhat is it a turd compared to? |
edges aren't necessarily that great for much
if it's all you can afford might as well. just don't expect much. straight piping is just allowing more exhaust to escape faster. maybe your HPOP isn't pumping hard enough? maybe your fuel pump can't dump enough fuel to make smoke? idk just ideas. |
how are your up pipes
get a tony wildman
when i saw this thread, the jeff dunham line came to mind from peanut. went something like this.. a turd is a turd, you polish a turd but its still a turd.
So a different chip and new fuel pump maybe?
Does anyone make an aftermarket fuel pump? And I was also thinkin injectors? Yes, no??? |
fuel pump will help. if you still have the stock injectors and hpop, then that should be the main issue. you wont get much out of those injectors. upgrade to stg 1 or 2. im told the single shots might give more power then the split shots.
Jeff dunham is funny as hell........watched him on tv like two hours ago |
-Raul |
also get the napa 6637 ( i think thats the number) and that will help with the intake air flow. |
