Air Dog FASS or other options????? - Ford Powerstroke Diesel Forum
Old 09-28-2009, 04:08 PM
Im looking into The AIRDOG FASS system with the filter water seperator and lift pump.
Is the system worth the money?
Where would be the cheapest place to purchase one?
Are the worth Purchasing?
What other options do I have ?
Is it worth the time to build one?
Old 09-28-2009, 05:44 PM
the air dog is well worth the money. xdp diesel is the best.way easy to install.no drilling in the frame works awesome.
Old 10-04-2009, 07:28 AM
can I get a link to where I buy this kit at?
Old 10-04-2009, 01:18 PM
Will a fuel system benefit a "stock" truck any?
Old 10-04-2009, 01:19 PM
wriott
Guest
Posts: n/a
yes it will, not in power but in getting fuel to the motor
Old 10-04-2009, 01:20 PM
any mpg increases?
Old 10-04-2009, 01:22 PM
I think fass claims mpg and hp increase
Old 10-04-2009, 02:04 PM
Did the FASS last summer.
Pump motor failed in under 10 days.
Power on the dyno = Zero increase
MPG increase = Zero
It was also loud as hell.
The truck drove 200 miles with no fuel pump at all. (good'ol powerstroke) It didn't drive well, but it got me home.
I installed a new stock Ford fuel pump. Truck put down 342/699RW with stock injectors and the new stock pump. I don't see the need for a larger fuel pump unless you have injectors. & Even then...I'd go a different route due to reliability.
If I need more fuel......I'm going to install a Kenne Bell Boost-a-Pump for $299. Or even twin stock in-line pumps. It's not that hard to upgrade to AN fittings/lines & make your own pickup if needed. The FASS pickup is nothing special.
Old 10-04-2009, 04:02 PM
Air Dog!!!!
Old 10-04-2009, 07:54 PM
Due to the design of the 7.3L injection system, as long as the fuel bowl stays full of fuel, there is no power or fuel economy gains from a fuel pump upgrade.
