Mods for heavy towing
I want to add some power for pulling heavy loads 18K lbs. I also want to keep it fairly quiet in the cab. I have installed guages and bypass filters on tranny, oil, and coolant. Where should I start. I don't want to give up any reliablity. I was planning on the diy tymar filter but after reading I am afraid it will be too loud. Was thinking about a Walker BTM. Any suggestions. I want my 7.3 to have about the same power as my 6 liter as it pulled the same load well stock it just hasn't been reliable, and I don't want to give up any reliablity on this truck. Thanks for you input.
I would do the Ford AIS intake and replace the tranny coole with the 6.0 one.
Tranny temp pulling was right around 190. Isn't that pretty good?
thats not bad but the cooler the better, if you cant find a 6.0 cooler dieselsite sells the v10 cooler which is also bigger than the 7.3 cooler and a little cheaper
The 6.0 cooler is the biggest you can get and you want a huge cooler when pulling heavy loads. Gauges, intake ( Ford AIS) , Exhaust = you don't need a new 4" system, sounds like you have read some of my posts, the BTM will work great for you, Then I would add a valvebody to the trans to shorten the sifts, long drawn out shifts aren't something you want when towing heavy. I would just look at my mods and copy them. Not to be a wise guy but I built my truck for reliable towing first and power second. I have towed close to 20K in Hay bails and granite on several occassions and it did amazingly well, much better than a 6.0 would have!!! Then you need a good towing tune, for that kind of weight you want a 40hp tune, 60-80 is to much for 18K and you will probably have EGT issues. I would call Jody!! Tell him if you get a VB, and you really should. PM me with any ?
NCH |
Agreed. I put the BTM on my stock 01 7.3 Auto and it really woke up pulling my 8K 5er.
I will say this, if you do need a new system due to rust or whatever, it is cheaper to buy a 4" system than a 3.5. But I would leave the stock down pipe or you will loose bottom end. NCH |
