Originally Posted by seanhankinson
The other thing i noticed when i run just the DP is when the truck shift gears it falls flat on its face it blows off all the boost. When i took the DP off and installed the SCT it took that problem away that was the reason for the big head wastegate actuator maybe i need to get DP to flash the chip and make sure its right. It was on the truck when i bought it and the boy that had it didnt seem to know what he was doing.
Check the map line to see if anything is installed for preventing overboosting. I doubt there is. What is happenign is when you go over 21 psi of boost(which you should in the 80e) the check engine light will come on for overboost code and the truck will defuel. Like I said, Jody is asking for the max in his tuning. The SCT may not be. Depends on how it was set up.
If you want Jody to check out the tunes send it in to us and he'll check them out.
Diane
