Tw Tunes or Dp tuner? - Ford Powerstroke Diesel Forum
Old 09-13-2009, 05:54 AM
Got a 99 F350. I do alot of pulling with this truck, most of the time heavy. I haul portable buildings and the wind load is the biggest factor, makes the buildings feel three times as heavy. I have a superchip 1805 and i have to keep it on the tow safe mode which feels like it is so held back. my brother has a dp tuner and his truck is insanely faster than both of my trucks. The main thing i'm looking for is a chip that will help me when i'm towing without hurting my motor or trans. I've already had the trans done once before and not looking forward to it again. I'm looking for opinions here, not wanting anyone to dog on one or the other. just want what is best for my truck and what i use it for. Thanks guys
Old 09-13-2009, 06:29 AM
I am quite impressed with the TW chip in my brother's truck. The transmission tuning is good considering how the 4R100 works. It's partly mechanical and partly electric, so you can't do the nifty magic that you can with the all electric 5R110.
What I would recommend (I know this sounds hard) is removing the superchip all together and running stock. It will save your transmission. Your new transmission will not last running with a superchip. I would personally only run a chip from TW, DP, or Power Hungry Performance (PHP). They all have a good reputation for transmission tuning. I have only used the TW on my brother's truck, but I have been impressed with it.
The other thing is that if you tow (and want more power too) you might think about upgrading your valve body in your transmission. It would be a lot more effective than any software tuning on the transmission. It's easy to do with the pan off. It bolts right on underneath the transmission. It increases the flow to the clutches, and makes them hold better.
One last suggestion is that if your transmission goes out prematurely again, get a Suncoast transmission and torque converter. They're just about bulletproof, and they will handle any amount of horse power you throw at it. Although, it will still not last long with the poor transmission tuning that Superchips is famous for. The fully upgraded transmission in my brother's truck cost $3800, and the torque converter cost $1200. The transmission has incredible firm shifts. The torque converter is out of this world. It has a higher stall speed, so you can start loads way more easily, and it won't burn your fluid as easily. It also has a triple disk lockup clutch. At idle speed you have to hold your foot on the brake, or your truck will drive away, even up hill or pulling a trailer. That's all the torque converter.
BTW, if your wondering why my brother's truck needed a new transmission if the tuning was so great from TW. Well there are two reasons.
#1 is that that truck towed every oversize, over weight, illegal (size and weight) load we threw at it with no chip or tuner at all. It got horribly abused. This lasted from when he got it (40K miles) till the power train warranty ran out (100,000 miles).
#2 at 100,000 miles he installed a superchip. He ran it on the high setting all the time, and he's not exactly gentle with his truck (see #1). He also didn't have a transmission gauge while he was doing any of this (only the useless dashboard gauge). The transmission went from normal operation to not working so great in about 15,000 miles.
He installed the TW about that time, and the transmission got better immediately, but I think there was already damage done, and it was just by the grace of the TW chip that it lasted another 15,000 miles. He figured that he might as well get a good transmission when he replaced it. We did the labor ourselves, so the overall cost wasn't much more than a shop putting in a re-built. And I know it was done right.
Actually when his transmission went out, it may not actually have been the transmission that failed. The torque converter exploded, so it definitely wasn't moving, but the transmission may have been fine. Although with that much metal garbage floating around the transmission afterwards, I wouldn't think the transmission would be much good for very long.
Old 09-13-2009, 07:35 AM
I think you'd be very happy with a chip from Tony. He's not only an excellent tuner... he's also a wonderful person -- which, as a consumer, is something I always look for. Good luck with your decision!
Old 09-13-2009, 07:55 AM
Well I have a dp tuner, coming from a superchips, and my trans shifts way better now and the power is awsome, they have heavy tow tunes also, I think most custom tuners do, I wanted the dp for the gauge pod selector and they're tunes!
Old 09-13-2009, 08:04 AM
go with php they tune my truck and i love it.
Old 09-13-2009, 10:39 AM
It's hard to get a better endorsement than one from a direct competitor. That says a lot about Tony Wildman.
Old 09-13-2009, 11:55 AM
TW!!!!!!!!!!!
Old 09-13-2009, 12:17 PM
Matts tunes are great as well
Old 09-13-2009, 12:18 PM
Go with Tony. He is a great guy and alot has been debated on the safety of DP's timing while towing.
Old 09-13-2009, 12:22 PM
I agree. PHPs post also says ALOT about their character, you notice how they dont come on here and push and push and push for you to buy their product, yet sit back and say good things about their competition, that right there says alot about them
