Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 7.3L Performance Parts
  #21 (permalink)
Old 09-09-2009, 04:33 PM
GM Duraturd GM Duraturd is offline
Originally Posted by Jake View Post
Noone else has any info on this turbo?
Just build get a compound setup
  #22 (permalink)
Old 09-09-2009, 04:38 PM
Jake Jake is offline
<-----GTP38R
I'll get right on build getting a compound setup.
I'll use the 38r as the atmosphere turbo and just rebuild my stocker for the other.
  #23 (permalink)
Old 09-09-2009, 04:40 PM
I meant build. And dont bring up using a stocker in a compound setup....you will get flamed trust me
  #24 (permalink)
Old 09-09-2009, 04:42 PM
harrys91rs harrys91rs is offline
KCR West Historian
Send a message via AIM to harrys91rs
I use it every time i tow a trailer, even a small one. Every little bit helps.
I'd like to hear if there is a sound difference too.
The Exhaust sounded a little bit louder going from stock turbo with ebpv to 38r with high flow. Didn't really sound any different that I noticed.
Not sure if its the turbo that makes it a little louder or the high flow outlet
That's when I had the stock injectors.
  #25 (permalink)
Old 09-09-2009, 05:04 PM
<-----GTP38R
Yeah, i don't think a stocker would hold up well on that.
Thanks for the input.
  #26 (permalink)
Old 09-09-2009, 05:12 PM
CloverLeafFarm CloverLeafFarm is offline
Tournaments Won: 1
i'm planning on getting the 38 as well down the road, however I have to convert my truck to late 99, so its going to be expensive so its going to be a long time
  #27 (permalink)
Old 09-09-2009, 06:04 PM
wriott wriott is offline
BUILT & BROKE BY ME
i deleted the EBPV when i had my stocker, reduced egts by about 50*, dont know what kind of difference it made with the 38r as it was already deleted. Jake you will be able to see how my 38R is down at SSS if you dont get one by then. i would say the loudness is about as much of an increase as the stocker is then adding the WW to the stocker... that difference is how much louder the 38r is over the stocker with a WW. (did that make any sense???) the 38r is loud and yes it can get annoying on long trips but it can be something to get used to
  #28 (permalink)
Old 09-09-2009, 06:16 PM
carnival owner mikey carnival owner mikey is offline
head hillbilly in charge
Send a message via Yahoo to carnival owner mikey
so if stock is say 5 stock with ww is 10 than 38r is 15?
  #29 (permalink)
Old 09-09-2009, 06:23 PM
<-----GTP38R
Actually if i get one it will probably be yours. Are you taking it off at SSS? But yeah id love to ride in it and hear it.
And after reading it twice it made sense.
  #30 (permalink)
Old 09-09-2009, 07:03 PM
DSTRBD DSTRBD is online now
The 38r is pretty loud and can get to be a little much for some on long road trips. The performance is well worth it though, most love the noise it makes.
BTW- We have these DEEPLY discounted right now for those looking to get one........only 2 left, PM for forum member pricing
