ok guys I need help ..where is the best fuel pick up upgrade and inner filter in side ..I want to get ride of that filter and put a inline filter for pre pump??? and what is the best kit ..I don't have the time to get all the pieces for it.and hunt them down ..un less someone has a parts list???LOL..but really who has good kit ..and can I delete the fuel bowl with COREY'S 4 line feed ..I want it out of there ..maybe PROS AND CON GUYS>>???
I am not strictly diesel's biggest fan but this kit has pretty much everything you need. A fuel pressure gauge might not be a bad idea if you don't already have it. If you are shooting for big power then an aftermarket pump or dual SD pumps might be in your future then a sump or a 5/8th draw straw is a better option.
How hard and time consuming is the install? I'm planning on completing their 500+ hp recipe early this summer. And the competition fuel system is first on my list
It's pretty straight forward.
Hardest part for me would be a toss up between dropping the tank (rusty straps) to add the pickup OR having to tighten a fitting on the front side of the head with 1/32" turn at a time
It can be done in less than a days time with 2 people
I already have coreys 4 line feed ..how hard would it be to mate up...I want to get the fuel bowl out.. I want the room and space... thinking of getting irates pre pump filter kit ..but it has 3/8 tube for fuel is that big enough..???I really want to keep COREYS 4 LINE FEED IF POSS..,,any body had or have this problem ..and how did u resolve this..........???? T/I/A
You would just need to find out what fittings he uses on the end of the feed lines. Might need to fab up something with a 5 port (1 input and 4 output) fuel block and maybe some jumper lines but shouldn't be too bad. Or maybe he has an upgrade kit, I would check with him.
This is where you do research away from the truck forums.
Instead of asking questions about different company compatabilities, call and ask. Thoroughly explain your idea, find out if they work. If not then find something that will work for the fuel setup your looking to buy.
I talked with Garry yesterday at irate..real nice guy asked all my ques and then some.will prob order this wked....and if 3/8s is plenty large.. then fine .. and is irates orange filter /water separator mainly for water...... or for water and foreign objects.. sediment ????sorry if I maid anyone go out there way ..??for my QUES..and as usual thanks in advance....
is it just me or do u guys see grenn spots on my signature picture ...?????PLEASE RESPOND
Related Threads
Ford Powerstroke Diesel Forum
5.4M posts
265.8K members
Since 2005
