Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 7.3L Performance Parts
Old 02-21-2007, 05:29 PM
S and B Filters Just another K and N?
Anyone use this filter before?
S&B Filters
Says it has 8 layer filtration. I like the airbox for a "cold air" intake.
Old 02-21-2007, 07:17 PM
MINI-MOD
Not sure on the performance of 'em, but check the filter efficency. It should be in the 99% and up range.
Old 02-21-2007, 07:20 PM
it is at 99.34
If you click the S and B in my first post it takes you to the web site with more info.
Old 02-21-2007, 07:22 PM
Airflow Rating: Flows 47.3% Better than the OE induction system at Vehicle's Rated Flow (627.6 CFM)
Efficiency Rating: 99.34% Efficient - ISO Course Dust
ISO 5011 Test Results (PDF): Open in New Window
CARB Exempt: Yes
EO Number: Not Required for Diesels
Installation Instructions (PDF): Open in New Window
Re-Oiling Amount for Filter: 44
Replacement Filter For Intake Kit: KF-1006
Oil Color: Red
Total Weight (including unit box): 30 lbs.
Dimensional Weight: 30 lbs.
Unit of Measure: Each
Length of Unit Box: 21.75"
Width of Unit Box: 13.125"
Height of Unit Box: 15.25"
UPC: 841372002847
For $200 it seems like a great deal!
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.3.2
