Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 7.3L Performance Parts
Old 02-25-2006, 01:35 PM
silverbullet silverbullet is offline
defueling
Hi new to the site
I am having a problem with my 7.3 defueling after 24psi of boost what can I do to correct this. I have a 2000 F-250 SD crew cab short bed.
Old 02-25-2006, 02:01 PM
super_stroke super_stroke is offline
Power Strokeaholic
a boost relief valve should geterdone.
Old 02-25-2006, 03:54 PM
has anyone used on of the boost relifvalves on ther truck
Old 02-25-2006, 04:12 PM
Power Strokeaholic
i've never had a defueling issue before. i'm sure some one here has used one of them valves before. maybe ramsmoker?
Old 02-28-2006, 11:20 AM
f450-freak f450-freak is offline
defueling
i have used the boost relief valve. actually its a pressure relief valve that goes in line to the map sensor. it fools the map sensor into believing that there is only 21-23 lbs. of boost being generated so it does not start defueling. i have used it before and after and have gotten 29 -30 lbs of boost after installing it 24 lbs before installing it. it works well but you still have to watch that u dont over boost ur truck. if your engine is old or you tow heavy loads ur boost may stay to high to keep the head gaskets from blowing.
Old 02-28-2006, 12:27 PM
Ramsmoker Ramsmoker is offline
Powerstroke Techie
Cool defueling
Relief valves are a must have. I also pulled the waste gate line off and plugged it. Ford vans don't have waste gates to start with. You can get the relief valves at defuser.com and blackclouddiesel.com. Cruz'n around on line I have seen other vendors. It won't be hard to find. All I have to do now is wait for Marc to nail me on the waste gate mod. Bill
Old 02-28-2006, 09:31 PM
drmiller100 drmiller100 is offline
do you think running 30 psi of boost will be hard on the stock turbo?
Old 03-01-2006, 06:14 AM
stock turbo
while a stock turbo can generate 30 lbs of boost it will be hard on it and may shorten its life span . its meant to run in th 15-19 area so im told.
Old 03-06-2006, 03:21 PM
I have a ported and polished turbo but i dont wont to shorten the life of my truck. So are you saying put the relif valve on my truck. I also have the waste gate un pluged.
Old 03-06-2006, 08:12 PM
defueling
well to be honest with you i have tried all those tricks like unplugging the wastegate hose, using a relief valve and a few more to attain 30 lbs of boost. then i relized that i bought gale banks tuners so i would have safe gaurds built in and here i am trying to over ride them. it sure is nice to feel the engine come to life with out defueling when u reach 24 lbs. but i got scared that it would hurt the motor the more i pushed. call me a chicken but i went back to using no relief valve and having the waste gate open when its meant to. i cant afford to blow a head gasket or something worse just to feel a kick in the pants. i still use the big hoss, six gun, big head, and a ported housing but i let the safetys keep me from being my own worse enemy. i wish i could build this engine to handle the extra power i would like to give it but my pockets are running on empty lately . they say the older u get the wiser u get. dont believe it im a perfect example of a 48 yr old that never grew up.....lmao
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
