Is there a DIY exhaust brake for 02' models? - Ford Powerstroke Diesel Forum
Old 07-06-2009, 02:18 PM
Is there a DYI exhaust brake for 02' models? oh yeah, its an automatic if that helps.
Old 07-06-2009, 02:21 PM
Yes there is. It is a rewiring of the EBPV on a switch to manually control it. It only works efficiently on autos with a TC lockup mod!
Old 07-06-2009, 02:56 PM
I never knew it only worked with the TC lockup mod.
I see where this would be a small issue not having a TC lockup.
But if you could elaborate that it would be appreciated.
Old 07-07-2009, 11:20 AM
Almostdunfukinwidit
Without locking the converter it does nothing to slow you. In fact using the EBPV as a brake while going downhill with the converter slipping can cause the trans to get hot
