EGT's Too Hot! - Ford Powerstroke Diesel Forum
Old 07-05-2009, 11:04 AM
EGT's Too Hot!
Well I hit 1443* really quick the other night just messing around town not even at 80 mph. I have a saftey defuel setting on the truck to defuel at 1300 degrees but I still got hot quick. Left it there for absoloutley no more than 3 seconds. Other than a larger exhaust what can I do for gettings these egts cooler without breaking the bank. Would a reburn to some custom tunes help?
Old 07-05-2009, 11:47 AM
Get some custom tunes and 4in tb exhaust. Thats what I got for exhaust straight pipe love the sound
Old 07-06-2009, 07:03 AM
Bullydog Flip-Chip
edge ez
SO you are stacking a bullydog and and an edge?
not a good idea.
Get a custom chip or a single good chip. and you should be good.
I have the stock setting (stock,40,60,100,140,high idle)on a TS chip and I have not seen 1300 yet even on the 140hp setting.
Old 07-06-2009, 07:12 AM
Cynic
Stacking will just cancel the other out on a international.. The edge will probably just raise the ICP beyond what the chip is putting out.
The only way to TRULY lower your egt's is to get a larger turbo or remove fuel. Removing the EBPV in the turbine housing helps, but it isn't a fix. Larger exhaust is NOT the fix as well considering that the STOCK exhaust downpipe flange is larger than the turbine outlet flange. Removing the CAT and muffler will help.
Old 07-06-2009, 07:21 AM
wriott
Guest
Posts: n/a
i have some tunes that will peg 1600*+ before i hit third gear. make sure you dont have boost or preturbo exhaust leaks
Old 07-06-2009, 07:27 AM
Cynic
1800-2000* hitting 4th here.
Old 07-08-2009, 09:04 AM
The edge is still plugged into the icp. Truck has no muffler or cat. Truck doesn't seem to move very good with the edge unplugged though. I guess I can unplug the edge ez and unhook the batteries and let the computer reset itself.
Old 07-09-2009, 05:25 PM
You dont have to unhook the batterys... The edge is nothing more then an over priced 10k mod...
Unhook it and get rid of that junk bully crap. Every truck I have ever seen with there chips has run hot.
