Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 7.3L Performance Parts
Old 07-02-2009, 03:06 PM
matthew7.3 matthew7.3 is offline
turbo
i have a question i was at a local parts store today picking up the wicked wheel i had ordered and the man behind the counter said i should turn the turbo up to get more boost anybody have a clue what he was reffering to
Old 07-02-2009, 03:16 PM
ianstew ianstew is offline
wah wah wah
I would think he is talking about fooling with the waste gate.
Old 07-02-2009, 03:21 PM
shu873 shu873 is offline
hillbilly keyboard racer
I've heard a lot of people use the term "turn up the turbo'' and most of them never had a real clue of what they were talking about in the first place. Then again he might have been telling you to unplug the wastegate and it would boost more so long as you had a chip to put more fuel to it. But then you run the risk of overboosting and limping it without a fooler. On older mechanically injected motors people used to call upping the fuel (makes more boost) "turning up the turbo" too.
My guess is the guy actually didn't have much of a clue.
Old 07-02-2009, 04:05 PM
layson layson is offline
You can do that all you want but you really won't see much gain... plus if you are over 27 or so psi you will tear up your turbo.
If you have a chip and a map sensor fooler then you can tighten the wastegate a little bit more... Or change it out for a turbomaster wastegate controller. They perform much better then the stocker.
