Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 7.3L Performance Parts
Old 07-02-2009, 10:50 AM
dusted4eva dusted4eva is offline
Speak up It's a 7.3 !!
Send a message via MSN to dusted4eva
TW Chip
Hi all. I noticed sometimes when I towing my camper the check engine light comes on even in the stock position. The light will only go out on Heavy tow and extreme. Any Ideas.
Old 07-02-2009, 11:16 AM
optx002 optx002 is offline
Your going to need to scan for codes.
Old 07-02-2009, 11:22 AM
Austinj427 Austinj427 is offline
Is it up in the RPMs?
Old 07-02-2009, 11:23 AM
RRonning1984 RRonning1984 is offline
Heavy Equipment 911
Ya check with a scanner because that does not sound normal at all
Old 07-02-2009, 01:06 PM
RPM's are normal around 1900 . I'm wondering if it is the overboost fooler I have on there.
Old 07-02-2009, 01:19 PM
SuperStroker10 SuperStroker10 is offline
if you have the fooler it should be doing its job. it sounds like to me it could possibly be the dreded 1211 code. icp above or below commanded range. basicly weak hpop or icp/ipr problem.
