911!!! OIL LEAK!!! - Ford Powerstroke Diesel Forum
Old 06-29-2009, 09:49 PM
Send a message via MSN to bigdog18
Exclamation 911!!! OIL LEAK!!!
I was comin home about 1/2 a mile from the house it feels like i loose all my fuel pressure. I pulled over got to look and on the driver side back bottom of the injector pump "there is what looks like a brass plug" and it has a straight stream of oil shooting out of it. Does any one know if it is just a plug or what it is, and has anyone else had this happen? Thanks for all the help in advance guys!!!
Old 06-29-2009, 09:53 PM
duct tape & zip ties
It is a brass plug. You need to head to a ford dealer, get yourself the HPOP O-ring kit. Replace HPOP O-rings.
I think the O-ring kit is like 48 dollars.
Old 06-29-2009, 09:56 PM
Good deal that will be first on the to do list tommorow!! Atleast thats a pretty easy fix. Thanks for the help man!!
Old 06-29-2009, 09:57 PM
If your going to replace one, replace all of them.
Old 06-29-2009, 09:59 PM
Yes sir i agree with you there if one is going then the rest prolly aint to far behind. Thanks agin man
Old 06-29-2009, 10:01 PM
No problem man, that is what we are here for.
Old 07-07-2009, 06:28 PM
There are NO brass plugs on your HPOP. They are all Steel. Hopefully you didn't rip the threads out of the pump body. If so, they can be repaired with a little work.
Good luck!
