will there be any benefits of putting a modded 17*hpop onto my early99 even though i currently have stock injectors?
In my experience I would say yes, but it would be a bigger difference if you had bigger injectors.
well i'm planning on doing tranny, then saving up for stage I's and the same time i was going to do the hpop, but i may just do the hpop now and see what happens, and once i get the bigger injectors in I know i will see a bigger difference
anyone else got imput, is it even worth doing now? or should i wait until i do injectors?
no you can do it now. It will help your stock injectors fire more efficiently and should give you better MPG (not a huge difference though) Are you thinking of something like the adrenaline pump. bang for the buck that is a good pump. If you are think termy's or the big stealth pump I'd wait until you do injectors. The expense is to great for a small gain.
will i be able to tell a difference in the difference, i know my milage may be better, but what else?
you will def. be able to tell a dif. better throttle responce. engine wont fall on its face on the top end as much. those 15's are nothing compared to the modded 17
