changing brakes on a 2wd - Ford Powerstroke Diesel Forum
post #1 of 12 Old 06-21-2009, 06:39 AM Thread Starter
colinmitchell111's Avatar
well my truck is due for pads and rotors, i checked some prices and my front rotors are over $100 a piece!.. i didnt realize it but the 4wd have the pop off rotors and the 2wd have the 1 piece rotors with the bearing in them.. so here is what im gonna do, im going to get new pads and just have the rotors turned so save some cash.. but the only problem is i have never done rotors like these. what do i do, i take the dust cap off, take the nut off, then the whole thing comes off? then after i get them turned, what do i have to do to grease the bearing and put it back in? how much do i tighten the nut? any help is greatly appriciated.. thanks!
04 F250 SC SB auto 4x4
5" Diamond Eye TB
High idle switch
Zoodad
EGR delete
Sinister coolant filter kit
Upgraded blue FPR spring
CCV Dump
Warn locking hubs
SCT with Looney
colinmitchell111 is offline
post #2 of 12 Old 06-21-2009, 09:34 AM
jcs
jcs's Avatar
Take the cap off remove the cotter pin nut washer then with your hand ready to catch the outer bearing pull the rotor out slowly once the rotor is off remove the inner bearing by taking out the oil seal the buy a pair of oil seals and some good grease pack the bearings with fresh grease put the inner back in the rotor install the new oil seal and put the rotor back on install the outer bearing washer and nut i dont know what the exact tourqe value (maybe around 25 ft/lbs or so) is for the nut usually i tighten the nut while i spin the rotor by hand just a little past snug but not real tite u dont want any wiggle or drag in the bearing hope this helps
early 99 7.3 supercab xlt s/b auto 4x4
08 Tailgate
Isspro gauges (boost,pyro,trans temp)
Ford AIS
jcs is offline
post #3 of 12 Old 06-21-2009, 09:45 AM
jamstoyz's Avatar
my rotors on mine have the sealed bearings seperate.
05 Single Cab Short Bed
*03 Turbo*Stroked Injectors*AFE Stage 2*Small mouth Intake*SCT With Eric's Extreme Race*4.30 Gear*Best ET 13.5@99MPH*
jamstoyz is offline
post #4 of 12 Old 06-21-2009, 10:09 AM
PMR = JUNK
Jake's Avatar
Quoted: 4 Post(s)
I have the capability of doing jobs like these.
BPS President
2000 F-250, forged rods, 38r turbo, BTS trans, hutch mod, TW tuning and Bad Night Special 50 horse Caterpillar injectors
Originally Posted by alberta 7.3 View Post
Yeah, I'd probably feel a bit drained after firing twice in rapid succession.
Jake is offline
post #5 of 12 Old 06-21-2009, 12:59 PM Thread Starter
well hell yeah, when you free.. you know how do do the rears too? i know the rear has the e brake shoes inside the rotor, ive never screwed arround with those kind too..
5" Diamond Eye TB
High idle switch
Zoodad
EGR delete
CCV Dump
Warn locking hubs
SCT with Looney
post #6 of 12 Old 06-21-2009, 06:11 PM
PMR = JUNK
Jake's Avatar
Quoted: 4 Post(s)
Not sure exactly when im free. Maybe this weekend. I've never messed with the rears like that but im sure we can get er figgered out.
BPS President
Jake is offline
post #7 of 12 Old 06-22-2009, 05:30 PM Thread Starter
saturday will work as long as i can find a shop open to turn the rotors..
5" Diamond Eye TB
High idle switch
Zoodad
EGR delete
CCV Dump
Warn locking hubs
SCT with Looney
post #8 of 12 Old 06-22-2009, 05:34 PM
PMR = JUNK
Jake's Avatar
Quoted: 4 Post(s)
Are you sure they can even be turned? They may be out of spec.
BPS President
Jake is offline
post #9 of 12 Old 06-22-2009, 05:38 PM Thread Starter
well i find out.. if not then they are goin back on with a cheap set of new pads till i get some cash for new rotors.. i would imagine they could be cleaned up a little.. maybe not fully lathed down so no grooves are showing
5" Diamond Eye TB
High idle switch
Zoodad
EGR delete
CCV Dump
Warn locking hubs
SCT with Looney
post #10 of 12 Old 06-22-2009, 05:43 PM Thread Starter
oh by the way, i ordered a 6637 today.. should be here by friday..
5" Diamond Eye TB
High idle switch
Zoodad
EGR delete
CCV Dump
Warn locking hubs
SCT with Looney
