06-18-2009, 05:03 PM
PMR = JUNK
Originally Posted by nboeger4
ok before i get thrashed for this question i already did a search and all i could find was a bunch of different information. Yeah, the search feature is worthless on this site, its no problem though, most of us don't care if people ask instead of search, those that do care, tell them to f off. i just got my egt guage hooked up the right way this time in the exhaust manifold and i was wondering whats the temp you need to start getting concerned about and if it stays there for how long? 1250 is when you want to start being cautious. I have run mine up to over 1500, no idea what they really were, it was buried, and i've had no problems. I wouldn't recommend doing that, as mine was on accident, but you must heat soak the pistons to damage them, and there is oil cooling them down. I woundn't run it over 1250 for more than a few seconds. im going to be pulling a 8,000 lb boat tomorrow and i just dont wanna hurt the truck and im not used to pulling a load this heavy with my truck. You should be fine. are you chipped? what setting do you plan on towing in? 8K is nothing for these trucks. I would be more concerned about trans temps than EGT's also should the temp guage move up and down a lot? Yes, it will vary with load or stay in the same position? no, it will move a lot and one more thing whats a good temp to shut the truck down at 250 is what i think i remember reading awhile back. I usually wait till 300ish, if ive been running it hard i just wait about 3-5 minutes then shut it down.
thanks guys
My responses in red.
