Horn is Randomly turning on. WTF
I am about to go crazy. My truck is randomly turning on its horn. It is just sitting in park and no ignition or keys are even inside the truck and then the horn will randomly turn on and continue to go off until i open the door. As soon as the door is shut the horn will not turn off right away. As soon as the dome light turns off the horn will continue to go off again.
When i disconnect the batteries the problem will stop for a couple days until it decides to randomly turn on again. WTF Anyone know the fuse number so i can disconnect it for now by the fuse. I do not know what fuse number the horn is connected to. Anyone else ever have this problem? |
Have you punched your steering wheel lately? I tried that mod and it didnt work to well!!! Ended up bending my contacts on the wheel. Thought I bent them back but the horn still came on till I either tapped it or slammed the door. Probably not even close to your issue but its a free bump for ya!!
bump..............
Please Help
Check your manual, it shows all the fuse locations.
thats the problem i left it at my fathers house an hour away.
disconnect wire at the horn
its not going off now. Any theories on the Ghost Horn. Randomly turns on for no reason. I have woken up to my horn going off at 2 am and as soon as i open the door it turns off. Then as soon as the dome light goes out the horn turns back on.
I disconnected the batteries for 2 hours and now the ghost horn is not happening. This happens like once a month where the horn will just turn on by itself |
FREAKIN" SPOOKY STUFF RITE THERE!!!
Your truck is possesed. Seriously I believe the clock spring in your steering wheel is messed up
