Need Hub Help - Ford Powerstroke Diesel Forum
Old 06-14-2009, 04:22 PM
Send a message via MSN to Jesse.James
Question Need Hub Help
Im about to tear my front axle apart to replace the inner axle seals. I also need to replace my front hubs, my hubs have an auto and on positions but you still can turn them in an out by hand. Are these considered automatic hubs? Can I get any set of hubs for a 2000 4x4? Also does anyone have any advice for the whole alxe tear down? I am also replacing one of the wheel bearing/ hub assemblies while its apart. Thanks in adance.
Old 06-14-2009, 04:28 PM
duct tape & zip ties
Your hubs are the auto/manual lock out hubs.
Replace front hubs with Warn lock out hubs, replace both wheelbearing assemblies.
Remove the axle and do complete rebuild with install of an ARB locker.
Old 06-15-2009, 08:51 AM
im thinkin i might go ahead and replace both hub assemblies while i have it apart. i have it about 90% apart right not i just need to remove the spindles and pull the axles however i do have both the hub assemblies off. I doubt ill put a locker in it, i wouldnt mind having one but i dont think ill spend the money on it right now. thanks for input
