AC is F-ing up. Help Please
99 F250 Super Duty 7.3
Recently charged my AC and it works fine UNTIL- I get going down the highway (60 mph) then it starts blowing warm air. When I turned off the highway the compressor kicked on again and worked for a little bit, then quit again. When I parked it here at home I opened the hood to see the compressor was not working at all. Later, I went out to see if would work. Turned on the AC, and it took a few seconds for the compressor to kick on, then it stayed on like it should, then after it had been running for a while it kicked off for a few seconds every so often, which I think is normal, right? So what can it be? Relay? Compressor? Clutch? Help please! |
i need to know also cause i dont get ac as well for almost the same reasons
Sounds like either a bad clutch or switch. Anyway, here's a
could also be the switch, had mine go bad and it would work intermittently
wheres the switch?
is that the 2 wire plug?
You didnt over-charge it did ya?They dont like it when there over about 46 on the low side,,with the rpms up around 1700.
is the compressor supposed to kick off occasionally? As to keep the evaporator core from freezing up completely?
