Help Steering Slack - Ford Powerstroke Diesel Forum
Old 06-12-2009, 10:28 AM
Help Steering Slack
Just put a new gear box in and had an alignment. Tie rods ball joints, rag joint everything is good to go, but i still have a little play in the wheel.... Could that be related to having a little play in the automatic shift? it is a little better than before i changed the gear box.... suggestions please
Old 06-12-2009, 11:19 AM
Powerstroke Junkie
The gearbox has adjustments to tighten it up, but to so in like 1/16 to 1/8 incriments, a little is a lot and if you get it to tight it will grenade itself.
Good Luck
NCH
Old 06-12-2009, 11:37 AM
were the pitman arm splines in perfect shape?
Best bet is to turn the wheel while someone else is looking at suspension components...
Old 06-12-2009, 11:48 AM
Check the steering shaft it's self it's a 2 piece design for saftey sometimes they get a little loose there.
Old 06-12-2009, 03:53 PM
the pitman arm was good to
should i have to adjust a new gear box
