Cleaning 7.3 turbo engine - Ford Powerstroke Diesel Forum
post #1 of 5 Old 06-08-2009, 10:45 AM Thread Starter
away's Avatar
Is there anything special to do about cleaning these engines? Can you wash with soap and water and let dry well before starting? Should I cover anything?forever!!!
2000 Ford Excursion
2001 F-250 Crew Cab Short Wheel Base
Pulling Trucks for
Drag Racing
1978 mustang II 363 CI SBF
1972 Maverick 532 CI BBF
away is offline
post #2 of 5 Old 06-08-2009, 10:49 AM
I pressure wash mine monthly using 25 degree spray nozzle. be careful around rubber fittings. that is what works for me.
korterman1 is offline
post #3 of 5 Old 06-08-2009, 10:54 AM
superduty4x4's Avatar
Cover up the power steering pump and air filter (if you have an open element intake) with grocery bags. Get the engine WARM (just barely warm to the touch, not hot!) and spray with simple green. Let soak, rinse with garden hose. Remove bags, start motor and let it idle to help dry up the water.
Pressure washers work too, but you run a much higher risk of forcing water someplace you don't want it (lots of electrical connections up there...)
97 F350 CCLB 4x4 PSD
superduty4x4 is offline
post #4 of 5 Old 06-08-2009, 10:59 AM Thread Starter
away's Avatar
Thanks guys
That's what I thought just wanted to make sure.
2000 Ford Excursion
Pulling Trucks for
Drag Racing
away is offline
post #5 of 5 Old 06-08-2009, 11:00 AM
ADMIN AND TECH
SCUFFY828's Avatar
Quoted: 3 Post(s)
simple green or purple stuff , works great and like said before , watch and just dont spray presure washer on components to long
ITS STOCK
SCUFFY828 is offline
