Turbo noise difference between trucks - Ford Powerstroke Diesel Forum
Old 06-08-2009, 09:42 AM
I have had a 2000 excursion 7.3.....stock
I have now bought a 2001 F-250....man this thing hauls.
I noticed right away the F-250 had an S&B Air intake kit as well as a predator stage II power module. You can really hear the turbo down low and hear the wastegate bleed off well......sounds great......still gets 17-18 MPG
I purchased another module to put on the excursion and I was expecting to hear the turbo louder but did not.
Could this just be the air intake by S&B....I can not find any other mods on the F-250
Also the excursion I can hear the warm up noise in the exhaust well on start up-Is this supossed to be happening this time of year?
The F-250 I never hear and it needs to warm up longer than the excursion. The 250 runs a little ruff until the water temp get up and it feels like when you start down the road for the first time it runs ruff for a secound still and you can feel something open up or something and then I know the truck is ready. After that no issues...it will fly.
What do I look for as differences.
Excursion below
F-250 below
Old 06-08-2009, 09:56 AM
wriott
Guest
Posts: n/a
the louder turbo noise is from the intake on the 250. check to see if the EBPV is still installed/or removed on the 250 for warm up time issues.
Old 06-08-2009, 10:05 AM
I see your from london, ky. I have family done there and my family reunion is at levi jackson state park.
Old 06-08-2009, 11:16 AM
it's most likely the intake noise, but if you really love the turbo noise than you need to do a foil delete on both diesels
Old 06-08-2009, 11:56 AM
dmd dmd is offline
x2
Most of the noise id from the intake. If you hear a "tea kettle" like sound when towing
that is called surge, and it will ruin the turbo. You will need a Wicked Wheel or an ATS ported housing.
Ditch the S&B (or K&N) as it lets way too much dirt through. If you dont believe it, just
go to their WEB page and research against stock filtering. The DIY (NAPA 6637) gives
stock filtering with great air-flow. This could save your engine.
If you want a real good punch of power, get a chip from Total diesel Performance or from DP. With any chip/programmer you must have gauges in order to know what
the engine is doing. You can cook your turbo before you know it.
Old 06-08-2009, 05:49 PM
Where does everyone buy these triple A-pillar gauges from?
Old 06-09-2009, 08:53 AM
A-Pillar gauges???
Old 06-09-2009, 09:01 AM
anywhere you like, I got mine from Raul at Stealth Automotive
Old 06-16-2009, 11:56 AM
What will "foil delete" do????
-DW
Old 06-16-2009, 12:19 PM
-DW
Makes the turbo louder. The foil serves no other purpose than to quiet the turbo
