Good place to tap into VSS wire
Hey,
Where is a good place to tap into the VSS (Vehicle speed sensor) wire? I understand it is gray and black, pin 58 on the PCM, but it is tightly bundled, anyone tapped it somewhere else? Thanks for the help |
Pull the airbox and you will find it under there.
I have an afe stage 2 installed, i don't remember seeing any wires under there. I'll take a look
*Edit
I was able to get VSS from the factory radio wiring harness in my 02 Excursion. I'll have to double check which pin but it was there. |
You say from the factory radio harness? i didn't have that option. Please look anyway though, thanks
there is a big loom of wires that run directly underneath of it.
... It is that one (the none speaker one) that has the VSS a grey/black wire, pin #9. I've been using it for my Avic.the other option is pin 58 on the pcm also a gray/back wire (not a fun bundle to pick). |
