Who has added factory fog lights? - Ford Powerstroke Diesel Forum
Old 06-08-2009, 03:11 AM
my truck doesnt have factory fog lights and im getting ready to add them along with my 05 conversion.. im planning on wiring them up to a toggle.. is there just 2 wires, 1 to the power and 1 to a ground with a toggle in there? thanks for the help..
Old 06-08-2009, 06:43 PM
my 99 didnt come with them either, i got to poking around, and on mine, behind the front bumper, below the drivers side headlight is a plug in for them, get the factory lights plug them in, turn them on via pulling your light switch tword you, its that easy
Old 06-09-2009, 02:10 AM
I am that hot
really, now i need to look, I really wanted to do this a while ago...
Old 06-09-2009, 04:37 PM
mine doesnt have a pull out switch for the fog lights and i have the whole front end off and im not seeing any plug.. maybe yours had them originally..
Old 06-09-2009, 04:39 PM
i think mine has the plug too. does it look like a probe with 2 wires going to it? i want to add fogs to mine too.
Old 06-09-2009, 07:58 PM
i did mine not long ago
Got my fogs installed
Old 06-11-2009, 07:44 AM
I installed them on my wifes excursion. Ran the power wires and ground to the battery thru a Relay, then a key on switch to a toggle in the cab. That way the lights receive full voltage rather then what ever the tiny wires the factory supples.
Old 06-11-2009, 07:49 AM
Cynic
That is the ONLY way to do it.
For the switched power, you can use whatever. But seriously, use a relay to pull direct power from the battery. Especially if you use HID or high wattage lights.
Old 06-11-2009, 05:01 PM
What relay is needed if wanting to use a toggle switch? Who sells them-Napa?
Old 06-11-2009, 07:11 PM
I've got a 2001 F-250 with fog lights. I was wondering how you turn these on??? Pull switch??? Lost??
Edit.....never mind figured it out......mine actually work.....wha hooo!!
