Coolant filter bracket?
I've ordered the Napa/WIX filter base to add a coolant filter to my 01' X - I thought I might be able to find a good location for it without needing to do anything too crazy with some some steel, alas I've not found a good mounting location that will not require the use of a 5 ton press to bend the length of 3" strap I want to use.
I was wondering if anyone was aware of a) a good flat mounting surface for a coolant filter head I might have missed or b) an outfit that will sell just the bracket - I can drill my own holes in the mounting surface for the filter head. |
Here's one. http://www.dieselsite.com/index.asp?...PROD&ProdID=94
Probably others, check the vendors sites. Might try a muffler shop. They could heat your strap with a torch and beat the snot out of it. They like that sort of thing. |
Here is how I mounted mine using the Dieselsite kit. It mounts with two bolts to the frame. Also if you mount it there it is close to the coolant reservoir so you don't need as much hose. You may be able to just buy the bracket from them.
Here’s an option you can consider if you can drill holes in a piece of flat stock. I used a piece of 4” X 9” X 3/16” flat bar that I purchased at Ace hardware to make a mount for my external transmission filter. You can use the same location on the driver’s side to mount your coolant filter. I hope this helps out.
Your a 6.0. Beware of the diesel site mounting location. I installed one on my 02 and took it off because my hood wouldn't shut all the way.
is there a write up on how to do this? I really want to install a coolant filter.
Here’s a link to another post with pics (post #13 on pg. 2) that I posted a couple of months ago. You can click the links on my post for information on the filter and filter base. You can also go to dieselsite.com and purchase the same filter and filter base with all the hose, fittings, bracket, and instructions as a kit.
Carquest coolant bypass system |
I'm switching to CAT ELC today and I'm going to just plumb it in on the end of my HIH under the driver's floorpan on the frame rail - there are plenty of spots down there to mount it.
I can switch mounting points later. I'm putting in PEX ball valves so at most I'll lose a few ounces of ELC when I swap mount points. That said does anyone know the pipe size of the plugs where the coolant is taken off for the heater and the one with the plug in the driver's side head? I think they're 1/2" - I'm clean and dry to go to the hardware store to buy some stuff and would rather not have to crawl under the truck to look again
Ended up bolting the filter head on the driver's side using one of the radiator mount bolts until I rig up a bracket - it's pretty darned tight and won't move without really cranking on it. So for now it's mounted and works fine. I'll see if I can order just the bracket from one of the vendors. Man the CAT ELC is really purdy - that red is cool! Found it locally for 8.99 a 50/50 jug.
