Vibration - Ford Powerstroke Diesel Forum
post #1 of 22 Old 06-05-2009, 05:54 PM Thread Starter
99BEIGEPOWERSTROKE's Avatar
Vibration
I have a vibration in my truck. You can feel it in floor under feet and also in the gas pedal some. You dont feel it all times but it does go away if you let off the gas pedal. It seems to be related to engine speed. Any ideas?
1999.5 FORD F250 SUPERDUTY 4X4 EXT CAB
7.3L POWERSTROKE DIESEL
6 SPEED
SWAMPS 175/146 SINGLE SHOT INJECTORS
SWAMPS TUNING
6" AUSSIE STACKS
AFE INTAKE W/ PRO GUARD 7 FILTER
VAN TURBO
4" SUSPENSION LIFT
315/75/16 BUCKSHOT MAXXIS MUDDER TIRES ON STOCK WHEELS (WINTER TIRES)
16X9 MOTO METAL 951 BLACK WHEELS (SUMMER)
COWL HOOD
99BEIGEPOWERSTROKE is offline
post #2 of 22 Old 06-05-2009, 06:14 PM
Randee Bowknee's Avatar
i have vibration in mine also.....something that i noticed is that i went to change my u jints in my 2001 that we had bought(used), and i noticed that my driveshaft was in backwards, so i installed it the right way thinking that was where the vibration was from and that wasnt it.
So i put my truck on stands and put the truck in geaf and looked for bent rims or whatever, and what it turned out being was my driveshaft. The yoke was wobbling around and had play....only would do it when i reached 40+ mph when i let my foot off the gas.
2001 F-250XL 4x4
K&N Cold Air
Foil Delete
05 Grille and Headlights
Wicked Wheel
Muffler Delete
4in turbo back exhaust
TW 6 position chip
Randee Bowknee is offline
post #3 of 22 Old 06-05-2009, 06:16 PM
hmmm...just noticed that you had said when your foot is ON the gas lol
2001 F-250XL 4x4
K&N Cold Air
Foil Delete
Wicked Wheel
Muffler Delete
TW 6 position chip
post #4 of 22 Old 06-06-2009, 07:39 AM
Stroked7.3's Avatar
Send a message via AIM to Stroked7.3
Wheel Bearing, Had the same problem. Put the truck on a jack, and spin the front tire with your hand. Youll probably feel or hear it resisting the turning a bit. Also pull in and out to check for play.
GHOST RIDER
2006 F350 CCSB
Bully Dog PMT-Gauges Only, AirRaid Intake, 4" Straight Piped w/ 8" Tip
8" Lift, Bilstein 7100s, Dual Stabilizers, 37x13.50 Toyo MTs on 22" XD Black Monsters
08 Tailgate, Upfitter Switch Hi-Idle Mod, High Beam Fog Mod, 6K HID Heads and Fogs, 5% Tint
Pioneer Z2/Z3, Kicker Components, JL JX 360/4, (2) JL 12s, JL JX 1000/1
Soon to come:
SCT w/TDS and SRL Tune
EGR Delete
Custom Traction Bars
Stroked7.3 is offline
post #5 of 22 Old 06-06-2009, 11:03 AM
devo's Avatar
I thought I had a wheel bearing going out. I could feel a vibration thru the pedals and floor board. It turned out to be the serpentine belt. It had split right down the middle.
1999 F350 XLT SC long box, 4X4, 7.3, 6 speed, Magnaflow 4" ss exhaust, ***** techni cooler, 6 position chip, DIY AEM intake, Sky leveling kit, 07 front, 08 rear
2002 E350 EXT van, 7.3, 03 grill
2003 E350 7.3, XLT
2002 F550 7.3 AT37G bucket
devo is offline
post #6 of 22 Old 06-06-2009, 07:40 PM Thread Starter
The bearings are good and the belt looks to be good. Any other ideas would be graet.
6 SPEED
SWAMPS TUNING
6" AUSSIE STACKS
VAN TURBO
4" SUSPENSION LIFT
COWL HOOD
post #7 of 22 Old 06-06-2009, 07:47 PM
Coal Rolling = Posing
Take your wifes makup mirror under the truck and REALLY look hard at all the ujoints and caps on your rear driveline. I was fartin around under the lift about 4 hours into a front end tear down, and noticed a split cap on one of the rear ujoints that you had to have the perfect angle to see. And it was causing my vibrations. Mine were on or off the gas though.
chvyrkr is offline
post #8 of 22 Old 07-05-2009, 08:06 PM
dubl_t's Avatar
also check the inner bearings where the front axle shafts go into the hub assembly.
mods thus far:
1704 tuner gizmo, BHAF, 4" DP to 5" stack, FPR w.109 shim, disconnected wastegate, plethora of gauges, 10k mod w/ 20k resistor (removed after it jacked up my connector), 17*HPOP (not really), hybrid sticks (I wish), some kinda badass turbo (another lie), mega body damage (that's gospel).
dubl_t is offline
post #9 of 22 Old 07-15-2009, 06:59 PM Thread Starter
Any other ideas. It still there...
6 SPEED
SWAMPS TUNING
6" AUSSIE STACKS
VAN TURBO
4" SUSPENSION LIFT
COWL HOOD
post #10 of 22 Old 07-15-2009, 07:22 PM
03_Turbo7.3's Avatar
hey dude,just an idea.. check your rear end, at lower speeds can you kinda hear it? like a roar....roar...roar...and it vibrates the floor and steering wheel sometimes and the gas pedal, both my last trucks...f350 7.3's did this, i went over EVERYTHING back to front then relized it was the rear pinion bearing, you may need a stethoscope and just touch the housing where the front pinion bearing is,,see if its loud...just an idea.
05+ coils, 10 Rear diff, box, tailgate, lights, bumper, Full 07 front harley swap...the list is endless.
AS IM RARLEY on here anymore...have a question ?? EMAIL ME
gladly answer any of your questions. OR search me on facebook. ill help out anyway I can !
updated as of OCT 28/2013
03_Turbo7.3 is offline
