i mover my power seat all the way back to vacume and when i pressed to go foward nothing :doh: so now when i drive i look like an a$$ can someone help quick. and i already cheched all the fuses are good.
You having problems reaching the wheel. Or the pedals.
Do all the other functions work on the switch. Like the up/down. Does it click when you push the button to move the seat forward. Or do you get nothing.
Get a multi meter and check to see if you have power at the switch. Then check to see if you have power at the motor when you push the button to move the seat forward.
To find out if it is the switch or the motor. You need to check it out. That is why I suggested you get a multi meter and start checking for power at the switch and the motor.
Also check the fuse, should be in the fuse panel under the dash.
could just need a hand. My seat doesn't like to move forward without some help... Especially If i'm sitting on it.... (I know let the fat jokes begin :lol
Related Threads
Ford Powerstroke Diesel Forum
5.4M posts
265.8K members
Since 2005
