it is a 2001 7.3. top of the valley is dry no fule in there but after 5 min of run time it starts to leak out of the back of the motor and around the bellhousing on the pasenger side into the tork cover and out of the tork drain hole. i can not see whare this leak is coming from. is ther return lines in the back of the head? it is not leaking from the fule filter area up top like i said the valley of the motor is dry and it allways take 5 min or so to start leaking out. any light on this mater would be hepfull thanks T
Can you see behind the tranfer pump? There may be fuel leaking from the lines back there and then running down the back... also check where fuel lines go to the back of each head, there is small rubber grommets that rot out sometimes and leak. Good luck.
I think if you have a stock truck it's just a plug but if you have a regulated return then you'll have fuel lines going to the back. Either way there is a way for your truck to leak fuel from the back of the heads
i am going to drop the down pipe and so i have more room to feel back there. going to try to run the truck some to try to get it to leak fuel befor the moter gets to hot and i cant feel for it.
You can get to it without doing that. It's on the valley side of the head facing the valley. I did not have to take the downpipe off to get to it when I did the regulated return. If you look to the left of my regulator you'll see a stainless braided line. It goes straight back to that plug or whatever is back there I can't remember for sure.
Related Threads
Ford Powerstroke Diesel Forum
5.4M posts
265.8K members
Since 2005
