- HOME
- FORUMS
- GARAGE
- ARTICLES
- CHAT
- CLASSIFIEDS
- VIDEOS
- TECH
- STORE
| Sponsored Links |
Yes there is a LPOP, that’s the pump that makes the around 50 psi oil pressure that lubes the entire engine just like on most all engines made over the last 100 years. As CSIPSD said, its behind the balancer. I thought 2 fellers with around 3,000 posts each might be trying to make a funny, especially after the comment about the HPOP being on the frame.
I guess the PSD engineers had trouble getting the oil pump to run right on the distributor shaft so they put it on the end of the crankshaft instead. Its actually fairly easy to get to but I haven’t heard of one failing, mine looked like new after 200,000, I replaced it anyway during my engine build.
....................If I said "distributor shaft" what would that tell you?![]() Are LPOPs expensive?
Low Pressure Oil Pump They rarely if ever "fail" they can get weak over time. |
In all due respect, Sarasota, you should start a new thread asking the question about your whine. I'm not trying to be a jerk or anything, but you'd get more responses with a new thread than with a dead one like this. Otherwise, I'm not 100% sure if an LPOP can whine. Possibly an HPOP. Have you checked the oil level in your reservoir?
| Sponsored Links |
