Trans. Fluid Mixed w/ Diesel Fuel????? - Ford Powerstroke Diesel Forum
post #1 of 20 Old 04-25-2009, 07:03 PM Thread Starter
joechatham69's Avatar
I just bought my first diesel and was told by the guy i bought it from that a secret trick to make a diesel last forever was to mix a quart of transmission fluid in with the diesel gas every 2nd fill up. Is this true?
joechatham69 is offline
post #2 of 20 Old 04-25-2009, 07:08 PM
Ryan Rønning's Avatar
Quoted: 6 Post(s)
Welcome to the ORG!
I have never heard that one before!
Project Frankenstein
1997 Ford F-350, Dually conversion, Cobra 29 LX CB, 12000 watt converter, All LED lights, PHP Hydra, 4" DP, Napa Intake, coolant filter, 140cc AD Injectors and lots of running lights.
Originally Posted by XPLOSIV View Post
Thanks. I'll give er a good wackin in the morning.
Ryan Rønning is offline
post #3 of 20 Old 04-25-2009, 08:07 PM
BIGWHEEL450's Avatar
Don't know about making it last forever but I have heard that it burns hotter than diesel and it helps clean injectors I fill the fuel filter with it when I change it
Sold 08 F-450
Rollin' ALCOA 22.5 Ten Lug
SCT Twisted By Eric
IDP
FloPro 4" with muffler + DPF/Cat Delete
S&B Intake
B&W turnover
It doesn't cost more to go FIRST CLASS you just can't stay as long
BIGWHEEL450 is offline
post #4 of 20 Old 04-25-2009, 08:09 PM
DavisME's Avatar
sounds bad. people have made their trucks last forever without that, so why risk it?
Scott
2000 XLT f-250 7.3L extended cab long bed 4wd
s&b intake, DP tuner on the way!!!!
straight pipe, no cat,
HPX oil crossover, foil delete,
zoodad, ccv relocation,AIH delete, guages, hutch mod and no hood insulation (soaked in diesel from a mess that involved 3 fire trucks and 2 hazardous waste trucks)
DavisME is offline
post #5 of 20 Old 04-25-2009, 08:13 PM
AFBLUE's Avatar
Trans fluid has alot of detergents in it which is said to clean injectors, and its an old school diesel thing. In 7.3 and 6.0 I dont think it will hurt anything. I would caution doing it on a 6.4 if it would have some adverse affect with the DPF.
I cant say its going to make it last forever, I dont see it hurting anything though. People run their PSDs on used motor oil, trans fluid, I myself run on Veggie. If its dewatered, and filtered, with a flash point of roughly 250-500deg it will burn in a diesel.
06 CCSB Lariat 102K
Factory 20s w/ Nitto Trail Grappler 35X12.5X20
Vegistroke 75,000 miles
2.5" Readylift Level
ARP Head Studs
EGR delete
Swamps 58V FICM
Isspro Gauges, EGT, Boost, Trans.
20ft of 4" straight pipe!!
SCT X3 BAMF Innovative Xtreme Race
AFBLUE is offline
post #6 of 20 Old 04-25-2009, 11:47 PM
dzchey21's Avatar
Like afblue said transmission fluid is like 90% detergents so it will help clean the injectors. My diesel instructor swore by a quart to a full tank, and then also filling the fuel filter bowl half full of trans fluid at filter change... His 12v dodge has like 300k on stock injectors and pump...might be something too it or could be the fact that he drives it like an old man.
single turbo'd 6.4
dzchey21 is offline
post #7 of 20 Old 04-26-2009, 12:43 AM
COINSLoT's Avatar
I was on a camping trip last Sept. at some music festival and my original motorcraft batteries finally gave up the ghost. The dude camping about 20 yards from me heard my solenoid clicking, fired up his rig, and came over to jump me. In the process of hooking up a set of cables from his 2 batteries to my 2, my jump box, and then letting it charge for close to 25 minutes, AND 4 failed attempts to start, before I finally fired it up, (sorry, reliving a nightmare LOL) I got to talking to him about diesels in general. He had a '96 Powerstroke and has been running it on straight used ATF for around 30K miles with no problems. Basically, he has a deal with a local shop where he goes and pumps their used ATF out into his own containers through a filter, takes it home, and filters it through a much finer filter before it goes into the truck. I think he's more of a backyard mechanic than anything else, but he told me it's probably not the best idea for my 2000. So, I guess you OBS guys are in luck...
2000 7.3 Powersmoke Sexcursion 4x4, 3.5" straight pipe, 10K Ohm resistor mod, 6637 filter, Foil delete, Wastegate delete, MAP fooler, Zoodad, Amsoil remote full flow and bypass filter.
COINSLoT is offline
post #8 of 20 Old 04-26-2009, 08:05 AM
AFBLUE's Avatar
There was an article in Diesel Power Mag a few months ago about it, someone running ATF in a 7.3 Excursion. OBS are almost like 12v Cummins, they will run on Bull Piss, because the injectors are not ramming large amounts of fuel in stock form, larger sticks you may see some issues, and its basically the viscosity of it. Veggie has the greatest loss of viscosity from heat, at 160F its within 95% of #2. ATF is next, but doesnt drop off quite as much as veggie, and UMO is last.
Verdict, do it if it makes you feel good. 1 qt to 30gals is 120:1. You mix 2stroke gas more than that.
Oh and people also use 2 stroke "ashless" oil in the fuel for lube properties.
Typically the cheaper the better for ATF or 2 stroke oil. the expensive ones have more additives that are made to resist heat, when in the end, you really want it to actually burn.
06 CCSB Lariat 102K
ARP Head Studs
EGR delete
Swamps 58V FICM
AFBLUE is offline
post #9 of 20 Old 04-26-2009, 01:37 PM
Jerryjust's Avatar
Send a message via Yahoo to Jerryjust
What Is Right?????
I'm a Newbie here, and need some help. Replaced 8 injectors and read here that 7 are AD and 1 is AE or AP,for #8.Is that right or not, any help?
jerryjust
2001 F350 Super Duty Crewcab.
89000 miles. 7.3L 4x4 Auto.
[Be who you are; say what you feel: Because those that matter,don't mind; And those that mind; don't matter.
Jerryjust is offline
post #10 of 20 Old 04-26-2009, 02:01 PM
jesilvas's Avatar
Quoted: 2 Post(s)
jerryjust
lol random
not sure about the injectors at ALL
but what i do know, you'll get a lot of helpful help if you go to the forum link at the top of the page and scroll down till you find the right place to ask that question
4R100, 2wd
330,000 + miles
jesilvas is offline
