loud poping noise
When I step on the brake fairly hard the front rt brake is making a poping noise. Ive took it to schwabs and they cannot find anything loose or broken. Doesnt make any sense, my brakes are fairly new in good shape all the way around. they work fine and dont pull in any direction.
anyone else have this issue?
i have the same problem but mine is on the left side.
anyone know what causes this to happen? thanks.
i have the same issue, and a buddy of mine did on his 2000 7.3, he had to replace his ball joints.. check them out..
Mine is doing it all so. I now it could be the u joints in the front axel and or the u joints in the
Drive shaft. Just my two cents |
ball joints is my guess
damn... are those hard to replace? kinda looks like it. i can tell the passgr side has been replaced so that is obviously what it is. thanks for the replies fellas. but are they hard to replace? expensive? thanks for your help guys, i love this web sight.
easy to do basic tools
IS IT SPENDY?
ball joints need to be pressed out and back in.. take the truck apart, then take the parts with the old joints in it to a machine shop, let them remove and replace the ball joints.. you will most likely need an allignment when it is all done.
