2003 F-350 blower motor questions - Ford Powerstroke Diesel Forum
Old 04-19-2009, 09:25 PM
When I turn on the A/C there is a loud noise and a strange smell coming from the passenger side under the dash is the blower motor gone ? If so where is it and how hard is it to replace? Any and all help would be appreciated. Thank you for your time.
Old 04-20-2009, 05:35 AM
What's the noise sound like? Is it possible a mouse got in your A/C system? That will cause a strange smell for sure, and isn't an unusual problem.
Old 04-20-2009, 06:57 AM
Its a loud humming noise, someone told me it might be the bearing went out in the blower its a loud rattling and humming. The smell almost smells like freon. The floor of the truck is not wet inside, so I don't think its the heater core, I think that's the part behind the glove box that look like a little radiator.
Old 04-20-2009, 09:31 AM
I had an explorer that the bearing went out in. At low fan speeds you didn't notice a thing but at higher speeds it would vibrate the whole dash and sounded like a heard of elephants running through the vents. If you smell antifreeze I'd bet your heater core is heading south. That's a pretty big sign of it even if it doesn't get the floor wet.
Old 04-20-2009, 11:40 AM
The smell only occurs when the the blower is trying to work and it only started having this smell since the blower motor problem. A couple days.
Old 04-20-2009, 12:58 PM
Blower motor takes about an hour to replace. It's not hard and it's all under hood.
Old 04-20-2009, 02:55 PM
Smile
***Problem resolved*** Takes about 10 min. to replace under hood back left side 3 bolts and out it comes. Noise was from the cage where the nut that holds the cage on had a crack right under it so the cage wobbles when it turns causing the noise. Thanks for everyone's help.
Old 04-20-2009, 03:00 PM
Cool you got it fixed. I was going to say about a 10-15 minute job but I got jumped on awhile back for saying I did a hub bearing in an hour so I shot overboard.
