Surging 7.3 - Ford Powerstroke Diesel Forum
post #1 of 7 Old 04-19-2009, 07:19 PM Thread Starter
'08 F350 FX4's Avatar
Surging 7.3
A friend of mine has a 7.3 that has started to "surge" going down the highway. Additionally, she says that people must think she can't drive a manual transmission because she is now "bunny hopping" down the road, mainly at the top of 2nd and 3rd gear. I thought it might be a semi-clogged fuel filter. Does the 7.3 have two fuel filters like the 6.0 and 6.4? Any ideas what might be causing this to happen? Thanks.
'08 F350 FX4 is offline
post #2 of 7 Old 04-19-2009, 07:21 PM
Hawker's Avatar
just the in tank and the bowl at the motor. easiest cure to the surge is a wicked wheel, but the combination of what you're decribing almost sounds like a fuel supply problem, like a fuel pump or something like that.
99 F-450 Crew Cab
DP 80E/80T/120R
ISSPRO gauges - auto conversion - built trans & billet triple disc
EBPV delete - Wicked Wheel
zoodad-aih delete-ccv
"If a big hammer won't fix it, you've got an electrical problem"
Hawker is offline
post #3 of 7 Old 04-19-2009, 07:22 PM
Cj Ford's Avatar
only has 1 fuel filter ... you need to get it on a scanner cold be lots of things
1999 F250 XLT 2WD 7.3, 6 spd, South Bend Con OFE, Detroit Truetrac, Tony Wildman tunes, Autometer Boost&Pyro, AFE Stage II, 4" MBRP Exhaust, 2" Daystars, 17x9 DC1 wheels wrapped in 33x12.50 MTZ's
Chris
Cj Ford is offline
post #4 of 7 Old 04-19-2009, 07:23 PM
Tony V's Avatar
ditto on the scanner.
2000 F-250 216k- smoke much?
Facebook: Anthony VanCamp
Add me if you'd like
Tony V is offline
post #5 of 7 Old 04-19-2009, 10:40 PM Thread Starter
Thanks for the replies. Sounds like she may have to bite the bullet and take it in to the dealer. Not sure when the last time her fuel filter was changed, that's why I thought it might be that. I'll tell her to have someone check out the fuel pump too. Any other ideas? Thx.
post #6 of 7 Old 04-20-2009, 05:59 AM
99PSD-White's Avatar
fuel injectors?
99PSD-White is offline
post #7 of 7 Old 04-20-2009, 06:06 AM
duct tape & zip ties
bigcountrysg's Avatar
He is not describing Turbo Surge which is what the WW is suppose to prevent.
He is talking about engine surging, which can be caused by fuel supply problem, bad injector, bad cps, or other problem that needs to be found.
You need a diagnostic scanner that is capable of doing KOEO and KOER tests. As well as scanning for DTC's.
Once you have the diagnostic scanner. Scan for DTC's, if none are found then do an injector buzz test, if it passes the injector buzz test, continue with a Cylinder Contribution Test. If it passes the Cylinder Contribution test and no trouble codes are found. Then I would suggest replace the cps.
But I believe the problem will be found with the diagnostic computer and running those two tests.
Your Actions Today, Decide Your Future Tomorrow
2005 6.0 Crew Cab Long Box Lariat, current truck
2004 6.0 destroyed by contaminated fuel
2002 7.3L burnt
bigcountrysg is offline
